| | | Forums66 Topics128,077 Posts1,056,012 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 11 Junior Member | | Junior Member Joined: Jul 2005 Posts: 11 | Is there suppose to be a door lock on the drivers door of a 1.5 ton? I have one on the passenger side. I seen another truck the same way. Thanks in advance.
Dcolella
| | | | | Joined: Jul 2005 Posts: 10 Junior Member | | Junior Member Joined: Jul 2005 Posts: 10 | Ours only has a lock on the passenger side. The reasons I have heard are 1)old laws that stated you were not to exit the vehicle into traffic 2) the gentleman was to unlock the passenger side for the lady and she was suppose to be polite enough to open the driver door for him.
Just what I've heard.
June | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Dcolella, Much safer to lock the big bolt from the curb than from the traffic side...don't want to get hit by an old Ford or International. Good old fashioned thinking from Detroit.
Stuart | | | | | Joined: Jul 2005 Posts: 11 Junior Member | | Junior Member Joined: Jul 2005 Posts: 11 | Thanks for the information! So how do you lock the drivers door?
Dcolella
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Dcolella, Push the inside handle down, scoot out the passenger door and lock with the key!
Stuart. | | | | | Joined: Jul 2005 Posts: 11 Junior Member | | Junior Member Joined: Jul 2005 Posts: 11 | Thanks Stuart! Can you tell I'm a rooky...
Dcolella
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Dcolella, The nice thing about this site is that we are all rookies!
Stuart. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | An owner's manual reproduction is a handy item if you're not too familiar with older vehicles...as is a repop shop manual. | | | | | Joined: Apr 2004 Posts: 31 Junior Member | | Junior Member Joined: Apr 2004 Posts: 31 | Yes, it is true, the key lock is on the passenger side door and is locked/unlocked from the outside. The driver side door is locked/unlocked from the inside. There is a 3/16 inch square shaft near the rear of the door, and the "T" handle goes on that shaft. To lock/unlock, you simply rotate the T handle clockwise/counterclockwise. | | | | | Joined: Apr 2004 Posts: 31 Junior Member | | Junior Member Joined: Apr 2004 Posts: 31 | Due to tunnel vision I was thinking only of the 1937 1 1/2 ton, sorry. Don't know about the other years. | | |
