| | | Forums66 Topics128,115 Posts1,056,294 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | | | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | Is the crack the problem or should I look for something else? | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 |
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Unfortunately, cracks in that area of the 230/250 engine and coolant/oil cross contamination is a chronic problem. It's virtually impossible to repair. It's time to go looking for another engine, or at least a block. Apparently, there's a hot spot that develops at the front of those blocks that promotes a lot of heat expansion and contraction which leads to cracking. The #1 cylinder is also prone to excessive taper wear. I've had to sleeve a few front cylinders to avoid having to bore all of the cylinders way oversize, or scrap an otherwise good block. Jerry
| | | | | Joined: Feb 2000 Posts: 5,219 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,219 | A lot of the 194-230-250 engines have the same crack, I had one just like it. I have read that the head bolt at the front drivers corner needs only 85 ft lbs of torque where the others get 90 or 95. The little bit of cast iron left after boring the water pump hole along with heat cycles cracks them. I have read where installing the water pump helps when torquing the head. Mine seeped coolant to the outside, there shouldn't be any oil in that location. There are head bolts that go into the water passages, so maybe one of them is letting coolant up into the top of the head where it mixes with oil. I scrapped the block, no one wanted to try and fix it, plus blocks were fairly easy to get at the time. | | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | What year 250s will fit my 66. A local yard had one in a early 80s c10 but it looked different than mine | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | All of them will “fit” but the later models had the intake integrated with the head and massive amounts of vacuum hoses and smog stuff. The integrated head was a real weak point, so, I would stick with the earlier versions.
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | I've got one of those late model 250's in my core engine collection. The head will either be trading material, or maybe I'll make it a boat anchor! Jerry
| | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | Ok I will try to find an older one. How hard to put in a 292 I know the passenger side motor mount is different what else? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 |
| | | | | Joined: Feb 2000 Posts: 5,219 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,219 | All the blocks are the same for the 230-250s, so years don't matter, the heads from the older engines will swap on to new blocks with no problems. The late model heads are not worth using as most are cracked, the none cracked ones do use a two barrel carb and likely run fairly decent if you can live with the smog equipment. As mentioned, the 292 is a little longer due to the heavy duty water pump, it is about 2" taller due to the longer stroke. The 194-230-250-292 heads all interchange. The 292 uses offset motor mounts, they bolt right in with the correct passenger side motor mount, the 292 has a mid engine fuel pump where the 230-250 has a fuel pump closer to the front of the engine. | | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | Thanks for all the replies. I bought a 250 from a friend of mine. I tore it down this after noon and it looks good. I ordered a re ring kit for it. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I thought all 194-230-250-292 were the same length except perhaps more V belt pulleys?
Ed
| | | | | Joined: Feb 2000 Posts: 5,219 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,219 | I believe you are right Ed, they do have more pulleys on balancers. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | 79 broncoowner Learned that 292 will crack between the lifter bores if overheated.Took a while to discover this,that was in 1970 was in a combine got way too hot. | | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | | | |
