0 members (), 126 guests, and 3 robots.
Topics128,101
Posts1,056,181
Members48,436
#1435127 12/29/2021 10:34 PM
I've unbolted 3 bolts on each side of the dash and one on each side of the steering column (8 total). It appears that there are spot welds on the top of the dash. I am not able to see them. Is that the case and how do you get at them?
1965 Chevy C10 Longbed Fleetside
Remove the windshield, the dash is half of the windshield pinchweld. Pat
Ouch, unless absolutely necessary I would leave alone.
1965 c-10 4 wheel drive conversion
Pix in the Gallery Forum
10-4. So it is a pinchweld - no spot welds? All to do is remove the windshield? Windshield has to be replaced anyway
Fox Offline
Why are you wanting to remove the dash? It is a PILE of work! I wouldn’t if I were me.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
I saved the dash out of a 1961 C10. There are A LOT of spot welds (pinch welds). Here’s the video.
Yikes, I see what you mean. Don't think I will be removing it. But I thought I had to for interior painting?
Fox Offline
No, you don’t need to. Painter’s tape and paper to mask it off. Be thorough so you don’t get overspray where you don’t want it.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Thanks for the replies
Unconventional Thinker
I will be doing this with my 65 C20. I know there has to be some rust from a leaky gasket, and the original owner made the dash look like swiss cheese with all of the screw holes to mount who knows what. I have a 65 AC dash sitting in the backyard that needs to be removed from the portion of cab it's attached to. Removing that dash will be my practice for removing the other swiss cheese dash. Not looking forward to it, as I have read and watched videos of dash removal, but in the spirit of having more access and repairing rust and replacing items under the dash like a two-speed wiper motor, and also the windshield, it will be worth it.
Shane
Shane's Toys...
2007 Forester XT Limited (2nd Owner)
1991 Cherokee Laredo (2nd Owner)
1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner)
1965 Chevy 3/4 Ton Fleetside (3rd Owner)
To each his own. I wish you all the best on your project. It is what makes us all different.
Unless there's some serious rust holes, I wouldn't remove the whole thing. Drilled holes can easily be welded up and dressed smooth prior to painting.
I don't think R&R of a dash would be easier than just working underneath it on things like a wiper motor. This is coming from someone who did quite a bit of sheet metal replacement.
But do what you must. wink
Thanks to the guys that have replied I have decided not to remove my dash. (As I have said before I probably wouldn't attempt a full resto. without this valuable resource).
But I was looking forward to being able to easily get at the rust on the back side of the dash. It is not too bad but I want to address it. Now I guess I'll be standing on my head to sand and prime whatever I can get at.
I appreciate the heads-up, it is not a portion of the project I am extremely fond of doing.
Shane
Shane's Toys...
