| | | Forums66 Topics128,076 Posts1,056,280 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Anyone have any info website,YouTube videos, On how to resize a stock 47-53 truck steering wheel ?? I put in p/s and don’t need the giant wheel not to mention my stomach and chest is to close as well thanks in advance Robert
This is no longer fun
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | What do you meam by "resize"? You can buy various diameters of steering wheels from your favorite parts vendor.
I have never heard of someone trying to change the size of an existing one. | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Just buy the size you want and use it. Restore your original as a winter project and set it on the shelf to go with the truck when it moves on.
| | | | | Joined: Apr 2016 Posts: 1,049 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,049 | I am resizing a 55 steering wheel for my 53 3100. I'm using a 55 wheel so I can use the factory turn signal mech. The column is the same size so it just slides on and nests with the wheel. I usually pick up the wheel and entire turn signal mech for about $20 at the junk yard. I plan to make silicon mold of the joining parts before disassembly. Then grind away the plastic and cut the steel structure and TIG the new wheel on. Then fill, grind and shape the new epoxy into shape. It will be a long process but I think it's doable. I have electric P/S and will be running a 1.5 or 2.0 steering quickiner. I have restored a few wheels and understand the structure. I have collected a few to play with. Thank you for your time.
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I find it easier but still a long procedure to cut the center out of the factory wheel and graft it to the center of the smaller wheel. Still have to do the welding, shaping and grinding. Usually go with an IDIDIT or Flaming River anymore which are pricey but not when I figure in shop hours for re-shaping an original.
Evan
| | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | The GM steering shaft spline and taper is pretty much standard for all their cars and trucks over a few decades. Just find a car steering wheel that floats your boat and bolt it on. Jerry
| | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | There's a 16" diameter Chevy car steering wheel on Ebay, but it's got angled spokes, not flat ones. That will reduce the diameter by a few inches, but it will also move the rim closer to you. Original equipment truck steering wheels are 19" in diameter. Jerry
| | | | | Joined: Oct 2012 Posts: 130 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 130 | Take a look at the back of your seat. Consider having a 1" or 2" of padding removed. I also had a problem with my belly to close to steering wheel. Had a shop redo padding on back and it fixed problem. | | | | | Joined: Mar 2007 Posts: 3,410 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,410 | Some years back Classic Truck Magazine had an article on cutting down a stock steering wheel. They used 3 steering wheels to make one, it looked like a factory original once finished. I believe the with the choices in factory steering wheels you should be able to find on that fits your needs. Save your original as Martin suggests.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Thanks for all the feedback on this topic I will do some more research on another steering wheel that will work well with my stock steering column.
| | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | FYI:
I think Classic Truck Magazine sold out to Motor Trend (the link I posted above).
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | I found a wheel from a Fiero at Pick your Part. It has 3 spokes similar to the original wheel and has a slight dish to it. I replaced the horn cap with one from a mid 70's Camaro and used a bowtie emblem in the center. Also installed the stock turn signal cancel plate and it works well. Fred
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I saw a thread elsewhere where a 1960-66 C10 steering wheel that was “shrunk”. The work was more than I would want to put into a project, but the result looked nice. The diameter of the wheel was made smaller by cutting the spokes shorter and then re-welding them to the hub. Sections were removed from the outer ring and then the pieces that remained were placed in a jig to align them so they could be welded together again into a smaller ring. Most of the original wheel outer plastic (or whatever polymer it is) was retained but the gaps where the welding occurred were filled with an epoxy much like JB weld and shaped to resemble the original wheel material. All done and painted it looked nice but not what my time is worth. Just saying.
A smaller diameter aftermarket wheel is worth the money IMO. I will say that the aftermarket wheels do a poor job at helping the average Joe figure out how to make the horn work again when installing a new steering wheel. That’s been my stalling point when I think about installing the new wheel I still have in the. I’d on the shelf.
| | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | The link is on page one if you want to use it for reference.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | The link is on page one if you want to use it for reference. Yes indeed. I passed right by that link as I scanned the replies. Looks to be the same set of pics I saw some time ago. Good reference! Well, my description pales to that thread with pics. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Itroca 52 Sure you can re-size a steering wheel,get one that needs help,cut it down to your dimensions weld metal frame. Make a mold the shape you want pour in epoxy,file and sand,paint. Not rocket science !! | | |
