8 members (Donf, 57 Drifter, baldeagle, HandyAndy, gswbbc, tclederman, Cosmo, 1 invisible),
122
Mod | | | Forums66 Topics128,040 Posts1,055,478 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2021 Posts: 33 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 33 | Hi.
There is not 1 digit readable on my odometer. Is this something i can take out easily? Can i change the gauge, rollers or decals myself? Who has some experience in this.
Thanks | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I've not tried rebuilding one myself. The classic speedo rebuilder I use in Cushman Speedometer in Wichita KS. https://cushmanspeedometer.com/
| | | | | Joined: Nov 2021 Posts: 33 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 33 | Additional info. I live in the Netherlands. So sending it somewhere is a bit more difficult | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Oops. I see that now. Hopefully someone with personal experience rebuilding one will be along to help. Good luck.
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | You can buy decals and rebuild it your self. Just takes patience and follow directions closely. Harold https://oldchevytrucks.com/1934-1946/decals.html
Harold Is a restoration ever finished? | | | | | Joined: Apr 2020 Posts: 322 Professional procrastinator | | Professional procrastinator Joined: Apr 2020 Posts: 322 | It has been a while but I did plenty of them when I was a young man. The trick is to go slow and carefully. Document what you are taking apart so you will know exactly how it goes back together. You will need to identify at least one number on each wheel so you can position the decal strip properly otherwise when the 10th's wheel gets to 6 it might rotate the 1's wheel and so forth.
1947.2 GMC 1/2T SWB panel 1947.2 GMC 1/2T long bed 1948 GMC 1/2T short bed
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I have rebuilt one and it isn’t terribly difficult. I also used a reproduction decal kit and it turned out well. The worst part is taking off the speedometer needle off its pivot point. That is the absolute worst part because of the VERY fragile nature of that needle on the shaft. After that, go slowly, take pictures, and you’ll have it back together in no time. Here is a sort of “before and after” of two speedos I had. Both were in this kind of rough shape when I started. You can do it. This was the very first speedo I had rebuilt and it went fine. Just be CAREFUL taking off the needle. These old chevs\GMCs aren’t sitting around in farmers’ fields in the Netherlands like they are in Canada and the US! I had 3 speedometers as backups just to be sure I had enough parts, in case I broke something. https://photos.app.goo.gl/YEOFa2AbSgJQURDt2 | | | | | Joined: Sep 2021 Posts: 56 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 56 | The odometers of a 1945 chevy aren't too hard to disasamble. Just make enough pictures of your disasambly so you know where everything goes. Unfortunately Prinstruckshop doesn't have te decals. So you probably need to get it shipped from the US. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Use a common eating fork to remove the speedo needle.
| | | | | Joined: Nov 2021 Posts: 33 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 33 | Thanks all for the valuable information. I will go on the hunt for the decals.
Update: decals ordered. Now wait for them to arrive in the Netherlands
| | | | | Joined: Dec 2012 Posts: 122 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 122 | If the decals don’t work out for you…
I purchased a new assembly of numbers when I refurbished the speedo head on my ‘46. It’s held immobile at all zeros with a plastic clip which you pull out AFTER you install the new assembly. If you remove the plastic clip before the assembly is securely in the head, you spend the rest of your life getting it reset back to all zeros (don’t ask how I know that).
I’m of average mechanical skill and am very pleased with the results. Greg | | | | | Joined: Mar 2014 Posts: 4,479 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,479 | I posted free templates for printing these decals on waterslide decal paper. Here's a link: https://tinyurl.com/yc54nsua Man it would be nice if we had Tech Tips or some sort of repository for stuff like this. The last odometer I re-did looks just like new.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | I purchased a new assembly of numbers Greg, Where didyou buy the odometer unit? Harold
Harold Is a restoration ever finished? | | | | | Joined: May 2015 Posts: 11,009 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,009 | Jim Carter has the whole odometer unit to put into your speedo. Link
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | im Carter has the whole odometer unit to put into your speedo. Link [oldchevytrucks.com] That unit is for the 1937-1939 & 1947-1954 Odometer. JC says this will not work in 1940-1946 trucks. Harold
Harold Is a restoration ever finished? | | | | | Joined: May 2015 Posts: 11,009 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,009 | That unit is for the 1937-1939 & 1947-1954 Odometer. JC says this will not work in 1940-1946 trucks. Harold Interesting that there's a gap in the years. I didn't notice that.
