| | | Forums66 Topics128,079 Posts1,056,296 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 11 Junior Member | | Junior Member Joined: Jul 2005 Posts: 11 | Hi Guys, I just got my 45 this weekend! Does anyone know how I can tell if it's a 1-1/2 TON OR 2 TON.
Dcolella
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | congrats.
got any pictures?
Also, typing ALL IN CAPS on an internet message board is considered shouting... just so you know.
Welcome to the 'Bolt.
-W | | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | Try the VIN Cruncher (see the News link above) ... and maybe that'll help.
Welcome to the Bolt. The caps thing -- it's also harder to read.
And get her in the gallery!
Peg
~ One of many.
| | | | | Joined: Jul 2005 Posts: 11 Junior Member | | Junior Member Joined: Jul 2005 Posts: 11 | I apologize for the caps, I didn't realize they were on... I'll get some pictures for the gallery.
Dcolella
| | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | A two ton will have the gusset plates mounted on the side of the frame rails,some 1-1/2 tons too.But a real two ton has a slightly larger front axle with king pins measuring about an 1-1/16 in diameter,the 1-1/2 ton pins measure just less than 1 inch.The front hubs are different also,I believe a 2 ton has a 6 bolt hub cap. | | | | | Joined: Jul 2005 Posts: 11 Junior Member | | Junior Member Joined: Jul 2005 Posts: 11 | Thank you! I do have the gusset plates and larger king pins. 5 lug wheels in front though. The gentleman I got her from seem to believe it was two ton because the king pins where larger than the 1-1/2 ton. Thanks again always like the feed back on these old trucks
Dcolella
| | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | There weren't any 2-ton trucks in '45, were there? My references only show 1.5-ton big bolts through '45, and the 2-tonners don't show up until '46 (model year, not calendar). I'm assuming Chevy. What's the serial number prefix?
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
| | | | | Joined: Jul 2005 Posts: 11 Junior Member | | Junior Member Joined: Jul 2005 Posts: 11 | Hi Curt, Thanks for your reply. The Prefix is MS so it must be 1-1/2 ton. Thanks to all for your replies.
Dcolella
| | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | The only 2 ton trucks built by Chevrolet prior to 1942 were the Canadian Maple Leaf trucks. They were the first use by Chevrolet of hydraulic brake system on the 1935 models.
34 & 35 trucks are the greatest
