Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (3B, 1955 1 Series), 36 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#1428073 10/26/2021 9:14 PM
52 gmc
When it comes to painting the grill, it looks like the only way to do it well is to drill out the rivets so I can straighten the vertical pieces and clean it up good. Looks like I could do a decent job painting it reassembled.
Is that how you guys would do it? Or paint it apart?
Also would you use rivets or the nut and bolt method to reassemble?
Not too concerned about factory looks.
Paul
1952 GMC
Starting with a basket case
In the Project Journals
1967 GTO
1967 Firebird
pauld #1428319 10/29/2021 12:05 AM
Paul,
Yes, on my '51-3100 I completely disassembled the grille assembly to body work and paint the parts separately. You can either drill out or grind the rivets out. For reassembly I used bolts and nuts, there are several vendors that sell "complete hardware kits" for these grill assemblies. I hope this helps!
Charlie
'51 3100 5-Window (Restomod in progress)
Professional procrastinator
I took mine apart. I had to for chrome purposes. I cleaned and painted the verticals then assembled it all with rivets except for a couple ones the rivet gun could not get. I used screws and nuts for those. You can't even see them.
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
Former BMW Rider
Former BMW Rider
Here's an old thread that discusses grille disassembly and fasteners. I used the threaded fasteners to re-assemble my grille and included some pics too.
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
Bond Villain
Bond Villain
I completely disassembled, restored and reassembled a grille as part of a frame off resto of a '49 4400. I found it to be simple, easy and kinda fun. I was *very* pleased with the result. I used the nut and bolt kit from Jim Carter. For cutting the original rivets, I used a dremel with the teenie cut off disc.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
pauld #1428444 10/29/2021 10:47 PM
Moderator
Moderator
2 Online: Content
Is that Charlie in powder blue?
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Bond Villain
Bond Villain
Don, No -- That truck predated Charlie.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Moderator
Moderator
2 Online: Content
Thanks John, I thought you went crazy there!
Don
"The Flag Pole"
1953 1-ton pickup
I bought stainless steel nuts and bolts for mine.
pauld #1428578 10/31/2021 12:50 AM
Bond Villain
Bond Villain
Don -- I did go crazy. I'm over it now.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
I used #10 stainless bolts/nuts/locks, worked well.
Thanks for all the input. I have renewed confidence I can git er dun
1952 GMC
1967 GTO
1967 Firebird
Drilled out all the rivets, did the needed body work and managed to reassemble. I like how it turned out.
1952 GMC
1967 GTO
1967 Firebird
Nice
