6 members (Gdads51, tclederman, 1955 1 Series, Otto Skorzeny, chemanic, 68ironhead), 134 guests, and 2 robots.
Topics128,082
Posts1,056,303
Members48,441
#143489 07/18/2005 11:25 AM
Junior Member
Junior Member
Hi Guys, I just got my 45 this weekend! Does anyone know how I can tell if it's a 1-1/2 TON OR 2 TON.
Dcolella
#143490 07/18/2005 1:49 PM
Socket Breaker
Socket Breaker
congrats.
got any pictures?
Also, typing ALL IN CAPS on an internet message board is considered shouting... just so you know.
Welcome to the 'Bolt.
-W
#143491 07/18/2005 2:30 PM
Try the VIN Cruncher (see the News link above) ... and maybe that'll help.
Welcome to the Bolt. The caps thing -- it's also harder to read.
And get her in the gallery!
Peg
~ One of many.
#143492 07/18/2005 2:32 PM
Junior Member
Junior Member
I apologize for the caps, I didn't realize they were on... I'll get some pictures for the gallery.
Dcolella
#143493 07/18/2005 9:43 PM
A two ton will have the gusset plates mounted on the side of the frame rails,some 1-1/2 tons too.But a real two ton has a slightly larger front axle with king pins measuring about an 1-1/16 in diameter,the 1-1/2 ton pins measure just less than 1 inch.The front hubs are different also,I believe a 2 ton has a 6 bolt hub cap.
#143494 07/19/2005 12:03 AM
Junior Member
Junior Member
Thank you! I do have the gusset plates and larger king pins. 5 lug wheels in front though. The gentleman I got her from seem to believe it was two ton because the king pins where larger than the 1-1/2 ton. Thanks again always like the feed back on these old trucks
Dcolella
#143495 07/19/2005 1:48 AM
X
X Offline
There weren't any 2-ton trucks in '45, were there? My references only show 1.5-ton big bolts through '45, and the 2-tonners don't show up until '46 (model year, not calendar). I'm assuming Chevy. What's the serial number prefix?
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
#143496 07/20/2005 11:02 AM
Junior Member
Junior Member
Hi Curt,
Thanks for your reply. The Prefix is MS so it must be 1-1/2 ton. Thanks to all for your replies.
Dcolella
#143497 07/20/2005 5:32 PM
The only 2 ton trucks built by Chevrolet prior to 1942 were the Canadian Maple Leaf trucks. They were the first use by Chevrolet of hydraulic brake system on the 1935 models.
34 & 35 trucks are the greatest
