3 members (KEVINSKI, Cosmo, ShopRag), 91 guests, and 9 robots.
Topics128,187
Posts1,057,212
Members48,465
Dear Friends: I brought a used 235 engine 6 months ago. It has all the accessories installed. I stored it upright in a climate controlled garage. There was oil in the crankcase. The crankshaft turned freely using just the fan and I last checked it 3 months ago. When I started to work on it this week end, , the engine is locked just as if it were bolted. Turning the damper with a pry bar fabricated for the purpose will not budge it either way, not a fraction. I pulled the pan and it is beautiful under there with an oil film covering everything. I pulled out the distributer and gear and removed the spark plugs and liberally sprayed in penetrating oil.
What could be causing this?
Best regards,
Joe.
'49 3100 "Sweet Caroline" because the truck has fabulous curves .... like Caroline!
Piston rings rusted to the cylinder walls, and/or valves seized in their guides. Pour a few ounces of Diesel fuel into all of the cylinders, and loosen the valve adjusting screws a couple of turns each. If the flywheel is still bolted to the crankshaft, use the chisel-shaped end of a long shepherd's crook wrecking bar between the starter gear teeth and the edge of the bellhousing. You can get a lot more leverage on the crankshaft that way, and you'll probably break the rusted rings loose. While you're at it, figure out a way to pry the rocker arms down against the valve stems a little. That will determine whether or not you've got seized valves. I'm betting on piston rings.
No matter where an engine stops turning, there will be a few valves open. This allows air (and humidity) to cycle in and out of those cylinders as the temperature changes. Next time you store an engine, put a few ounces of motor oil into all the cylinders, and then plug off the intake and exhaust manifolds or the ports in the head with duct tape to keep air from getting to the cylinders.
Thanks Jerry, you have helped me a lot on this build.
Crusing in the Passing Lane
One of the benefits? of living in the 'rust belt.'
Ed
Sometimes mice will get into the cylinders and have a potty break. There pee is very corrosive.
My Blog
Moderated
Moderated
Merry Christmas, I have just recently converted my 235 to electronic ignition. It idles fine but at acceleration it falls on its face. I have called the tech from Pertronix to get some insight and he suggests a bad ground between the distributor and ground. Any suggestions?
If you have points and condenser, install them to see if the problem goes away. If it does, its your choice whether to go back to Pertronix.
ApacheJr: I've had 2 Pertronix units fail with those same symptoms. Was very frustrating trying to diagnose. Will not use Pertronix anymore. Dave
