| | | Forums66 Topics128,106 Posts1,056,214 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 15 Junior Member | | Junior Member Joined: Jul 2005 Posts: 15 | I am tying to identify what model 1949 GMC truck I have.I was told it is a 1 1/2 ton.This is the serial # FC301 21474.Is this also the vin # ? Gross weight-13000 combined weight 22000.Thanks in advace!!! | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | FC 301, would be a, 300 series 1 1/2 ton. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | and yes, FC301-21474 is the VIN, w/ the last part being the serial# [production sequence number]
Bill | | | | | Joined: Jul 2005 Posts: 15 Junior Member | | Junior Member Joined: Jul 2005 Posts: 15 | Guys....THANX for the info!!! These old BIG trucks are just toooooo cool.Now I just need to find some parts! | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Bow Tie Bits maybe, or used anyway for big trucks, and Chevy Duty has some brake cyls, have to ask around vendors, most have some times, but not a stock item.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
