Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
8 members (MNSmith, frogfarmer, 1955 1 Series, walter74, Hotrod Lincoln, klhansen, TUTS 59, 1 invisible), 32 guests, and 3 robots.
Topics128,005
Posts1,055,258
Members48,418
Looking for a solid cone bit, nonstepped. Maxing at about 7/8" dia.
Similar to this one bit without the nub on the end.
I managed to lose a friend's so I must get a new one for him.
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
Insomniac
Insomniac
Interesting. They say to slip a washer over the bit to stop you from drilling the hole too big. But since the bit is conical, you will end up with a hole smaller than the washer's hole. I suppose you need to drill out the washer a little in order to get the desired diameter.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Former Workshop Owner
Reminds me more of a tapered reamer than a drill-bit.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Ex Hall Monitor
Ex Hall Monitor
Moderator
Moderator
2 Offline
Great job Tiny, you found it!
Umbrella Step Drill.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Curmudgeon
Curmudgeon
Every handyman's necessity.
Right up there with a "fits-all", "duck tape", screwdriver pry bar and a big "make it fit" hammer.
The step drill is used a lot for making holes in electrical panels to fit conduit and Romex connectors.
thumbs_up
back yard wrench turner
Originally Posted by Tiny
Thanks tiny, I just put it in my cart. Buying myself a Christmas present.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Moderated by  MNSmith
