0 members (), 159 guests, and 2 robots.
Topics128,260
Posts1,058,342
Members48,485
#1434391 12/22/2021 4:30 PM
Can a 235 by dropped into a '50 GMC half ton without too much trouble? I know brackets, cables, linkage, and fasteners have to be considered. My questions involves radiator/firewall clearance and crossmembers. Thanks. Have a low mileage '62 and access to a '50 Deluxe cab GMC half ton with no motor or trans.
If that 62 engine is a 235, it's close to a bolt-in swap. The front motor mount bracket will have to be adapted, as the GMC engine is about 2" longer than the Chevy. The bell housing, transmission, rear crossmember, and clutch linkage should be a direct swap with the corresponding Chevy parts. The 230, 250, and 292 engines will require major modifications.
Thanks Jerry for your input. I will try to make this happen then!
