0 members (),
159
Mod | | | Forums66 Topics128,260 Posts1,058,342 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 38 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 38 | Can a 235 by dropped into a '50 GMC half ton without too much trouble? I know brackets, cables, linkage, and fasteners have to be considered. My questions involves radiator/firewall clearance and crossmembers. Thanks. Have a low mileage '62 and access to a '50 Deluxe cab GMC half ton with no motor or trans. | | | | | Joined: Feb 2004 Posts: 29,944 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,944 | If that 62 engine is a 235, it's close to a bolt-in swap. The front motor mount bracket will have to be adapted, as the GMC engine is about 2" longer than the Chevy. The bell housing, transmission, rear crossmember, and clutch linkage should be a direct swap with the corresponding Chevy parts. The 230, 250, and 292 engines will require major modifications. Jerry
| | | | | Joined: Oct 2009 Posts: 38 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 38 | Thanks Jerry for your input. I will try to make this happen then! | | |
