| | | Forums66 Topics128,088 Posts1,056,125 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 15 Junior Member | | Junior Member Joined: Jul 2005 Posts: 15 | Hi...I am new here,and there seems to be lots of info availible here.I just recently picked up a 49 GMC 1 1/2 ton,at least I think it is a 1 1/2 ton.Is there any place that brake parts are still availible? I am planning a SBC transplant as the engine is long gone,but I may use the original trans or go with a turbo 400.Are these logical for a transplant? Also is there a way to upgrade to disk brakes on the front? I may be asking questions you guys have heard a million times,and if so I appoliguise.But any help is greatly appreciated!!! Thanks!!! Eddie | | | | | Joined: Mar 2005 Posts: 59 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 59 | just a reminder that a turbo 400 dosn't have provisions for pto that's what keept the 4spd in my 44 grain truck
rh | | | | | Joined: Jul 2005 Posts: 15 Junior Member | | Junior Member Joined: Jul 2005 Posts: 15 | Mine did not have a pto.It does still have the original SM420 4spd,but the engine is long gone.I was thinking a 283 or 327 with a turbo 400 would work ok.I do not think the truck would be doing any more heavy hauling,so the 400 should be strong enough??? Thanx!!! | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I've never seen any evidence of a disk brake conversion for these. I've thought about adapting disks to one, but its going to be a challenge to figure out what disks, bearings and calipers to use. Please let us know if you solve that one...
I saw a '51 Chevy 4100 at a car show this weekend that has a 383 (stroker small block) and the SM420. It also has a 3-speed brownie that allows it to run 70 on the freeway.
I'd sure what to be sure my brakes were good before trying that!
Anyway, the owner said that even with the stroker motor he was disapointed at the performance when loaded, because the motor does not have the torque he wants.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jul 2005 Posts: 15 Junior Member | | Junior Member Joined: Jul 2005 Posts: 15 | I wonder if an axle out of a newer 1 1/2 ton truck could be fabbed in???
The stroker is more of a rpm engine than a torque engine.And it has a lot to do with what it has for guts.It just has to be built right.That stroker would be much better off in a 1/2 ton PU. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by RamblinGMC: I wonder if an axle out of a newer 1 1/2 ton truck could be fabbed in??? I think you'll find they are too wide, but I've not measured any. The stroker is more of a rpm engine than a torque engine. I called it a 383, but I may have gotten that wrong, it may be the long stroke 350 instead of the short stoke 400. Talking to the guy I think what he really needs is a 572 with an automatic.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jul 2005 Posts: 15 Junior Member | | Junior Member Joined: Jul 2005 Posts: 15 | Were there any 1 1/2 ton 4x4 trucks??? A 4x4 axle with disks would be nice too.
Somewhere,somehow it could be done/has been done.But as long as I can get the brakes going,and working ok,the drums will work.
A 454/turbo 400 combo would be nice too. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | some army trucks had all wheel drive I believe | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Some military trucks had 4x4 in the larger versions. A company called Campbell (I think) made a conversion kit for the larger trucks, just as NAPCO did for the lighter-duty trucks, but I've only seen one, it was on an old phone compnay COE that sold on eBay several years ago. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Hey Ramblin, Try, these two places, for your brake parts, Alretta Truck Parts (ask for Geoff) (508) 788-9409, or Brake & Equipment Warehouse (800)523-4632. You need to have your correct truck spec. info., so knowing, if you have a '49 GMC 1 1/4, 1 1/2, or 2 ton truck, is important. What does the ID Plate, in the driver door jamb, say. | | | | | Joined: Mar 2004 Posts: 6 Junior Member | | Junior Member Joined: Mar 2004 Posts: 6 | Just swap chassis's, that's what I did. I have a 49 1.5 ton cab and hood with 49 2 or 2.5 ton fenders, on an 89 1 ton 4x4 chassis with a 454/t400/np205 dana 60 front 14 bolt rear.
I just drove it from San Francisco to Flint Michigan in 5 days.
Everyone LOVES this truck.
49 gmc
49gmc | | | | | Joined: Jul 2005 Posts: 15 Junior Member | | Junior Member Joined: Jul 2005 Posts: 15 | Spanky....it is an FC-301...1 1/2 ton?
49gmc.....I have been thinking about that.I would like to keep it a 1 1/2 ton,but a 1 ton would be ok too.I just need to get a title for it.It had no title when I bought it,sitting a longggg time! And I would hate to use a later model title,all the Calif smog BS!! | | | | | Joined: Jul 2005 Posts: 6 Junior Member | | Junior Member Joined: Jul 2005 Posts: 6 | Ramblin, I discovered that the king Pins in your truck are the same used all the way to 1980. My front brakes/backing plates/Spindles are from a 1980 Chev C50 with the 5000# front axles. Works great and drums, shoes, and hardware are all readily available for the C50 | | |
