Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
The identification plate on the hinge pillar of my 50 3600 is held on by two small clutch head screws. I was curious if the FAM shows that mounting as an instruction. I was asked once why that plate wasn't riveted on, so I was hoping to find the mounting instruction to prove to myself and the person asking the question, that the screws were as the factory installed it. I looked through the really cool index for the FAM that was created,( thanks guys for that)and flipped through the pages in my FAM but didn't find it. Can someone point me in the right direction? Thanks
The FAM shows the data plate mounting, on Section 1. Sheet 10.00, but since it's a 1953 drawing, it calls out the rivets that were used in later trucks ('51 and later). Here's an article from Jim Carter that discusses the screwed on data plates. Link
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
