0 members (),
95
0
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 64 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 64 | The identification plate on the hinge pillar of my 50 3600 is held on by two small clutch head screws. I was curious if the FAM shows that mounting as an instruction. I was asked once why that plate wasn't riveted on, so I was hoping to find the mounting instruction to prove to myself and the person asking the question, that the screws were as the factory installed it. I looked through the really cool index for the FAM that was created,( thanks guys for that)and flipped through the pages in my FAM but didn't find it. Can someone point me in the right direction? Thanks | | | | | Joined: May 2015 Posts: 11,273 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,273 | The FAM shows the data plate mounting, on Section 1. Sheet 10.00, but since it's a 1953 drawing, it calls out the rivets that were used in later trucks ('51 and later). Here's an article from Jim Carter that discusses the screwed on data plates. Link
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2008 Posts: 64 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 64 | Thank you Kevin. I hadn't seen that article from Jim Carter. Always amazed at his knowledge. | | |
