6 members (WICruiser, Otto Skorzeny, Cosmo, RAC1812, cmayna, 1 invisible), 133 guests, and 2 robots.
Topics128,087
Posts1,055,982
Members48,430
#1433535 12/14/2021 6:37 PM
I have a 48 1.5 ton. Going to put a 235 in. Why is there 2 different rear mounts? The bigger one says its for a 1.5 -2 ton, smaller for 1/2 ton I assume. But the engine weighs the same and all the holes in the mounts are the same.
Probably an after market thing, but thought I'd ask.
skydog #1433536 12/14/2021 6:40 PM
Big Bolt Forum Moderator
I would assume the bigger one, will withstand more torque, may be a bit stiffer so it doesn't flex as much while trying to get more weight moving.
Mike
skydog #1433543 12/14/2021 7:08 PM
Big Bolt Forum Co-moderator
I was going to put fresh motor mounts in my truck. Where did you purchase your mounts? Mine is a 2 ton.
1948 Chevy 2-Ton
skydog #1433551 12/14/2021 8:16 PM
My original rear motor mounts ('51 3100) look like the ones with more rubber. They're still in decent shape to be reused
skydog #1433571 12/14/2021 11:29 PM
A friend gave me the smaller set and I think he said they came from brothers. Jim Carter had the bigger set.
