2 members (carbking, TUTS 59), 108 guests, and 2 robots.
Topics128,029
Posts1,055,416
Members48,422
#1432832 12/08/2021 11:14 PM
I am looking for a backup light to replace the "ultra " modern led fixture the previous owner installed on my 1941 AK. I would like a 12 volt led with a mountable housing that looks vintage. Any suggestions?
ronsway #1432849 12/09/2021 1:35 AM
Some put the lights in the round bed ends.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
ronsway #1432864 12/09/2021 2:42 AM
If I can't find a fixture they would work.
ronsway #1433372 12/13/2021 5:24 AM
buy a vintage set of driving lights and mount them on the bumper or....
Another quality post.
Real Trucks Rattle
ronsway #1433534 12/14/2021 6:36 PM
ronsway Watch for old tractor lights,then put in led bulbs for vintage look.
kevinski We had an 82 Buick once she said it had headlights on the back in reverse. You could see well back there,better than backing into something.
ronsway #1433540 12/14/2021 6:57 PM
The old tractor lights is a good idea. The only problem is all of mine have been "rode hard & put away wet".
ronsway #1433553 12/14/2021 8:37 PM
Ex Hall Monitor
Ex Hall Monitor
If your truck has the rectangle taillights you can probably use the 37-38 car backup light. It uses an incandescent bulb but that can be replaced by an LED if you wish. The link below shows it with the light housing above but it actually mounts below the taillight. I'll post a photo of the one on my 38.
https://www.chevsofthe40s.com/detai...ht_Assembly_Accessory_Like_Original.html
ronsway #1433575 12/14/2021 11:50 PM
I checked and they are no longer available- would have worked
ronsway #1433578 12/15/2021 12:27 AM
Ex Hall Monitor
Ex Hall Monitor
They're taking names for when they're available again. Give them a call. Also The Filling Station.
ronsway #1433588 12/15/2021 2:00 AM
Filling Station same status. I will call in AM
