3 members (Gdads51, Bill Hanlon, Otto Skorzeny), 65 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#1433188 12/11/2021 8:25 PM
Big Bolt Forum Co-moderator
Are the master cylinders for the big trucks the same as the smaller trucks, except for the hydro-vac?
1948 Chevy 2-Ton
NO, they are not the same...the bore is larger on the bigger trucks.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
You can check out the master cyls. in the Chevy's of the 40's catalog. I just got a catalog free in the mail and the master cyls. are fairly reasonable, I thought.
The big bolt MC has to be "fail safe"- - - - able to move enough volume of fluid to apply all the brakes, with or without the Hydrovac working. That requires a bigger bore and a longer stroke than the pickup cylinders.
I ended up have mine drilled and sleeved with stainless, probably outlast me. Very reasonable at a local shop,
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
These might be useful - for my 55 second series.
MASTER CYLINDER REBUILD KIT - UP33 - NAPA
MASTER CYLINDER - M21698 - AMAZON
52vff Don't try this at home ,I was wiring at a commercial oil field powder coat shop had the worst pitted wheel cylinder I had blasted and powder coated inside. Then Sunnen precision honed it back to size,it is still running on one of my storage rigs I use to keep brakes and driveline stuff alive. Now I don't know if domestic powder coat would work. There coating is used to protect oil field fittings from vicious downhole fluids in injection wells. .02 cents
Precision machine is sent out by me. I can do a lot but high precision or safety equipment is best left to pros in my book. Unless they come to me and we work together. ..
"Old Smokey'"
