7 members (fonz8261, Hotrod Lincoln, TexasJim50, TUTS 59, Jay R, TooMany2count, amtrakjoe), 78 guests, and 2 robots.
Topics128,134
Posts1,056,416
Members48,441
#1432842 12/09/2021 12:25 AM
I have a 3 speed transmission in my 46 1/2 ton. Notice that the bearing cover has been wielded and can not find a replacement. Will a 4 speed cover fit?
We are getting a noise that sounds like the through out bearing but the bearing is new. Any thoughts?
Thank you.
Check your PM.
Mike
1951 3100 5 window
Crusing in the Passing Lane
There should be about .750” clutch pedal movement before throw out bearing is engaged, if not, bearing will always be engaged and wear quickly.
Ed
