1 members (UtahYork), 80 guests, and 2 robots.
Topics128,049
Posts1,055,637
#143281 07/04/2005 6:32 AM
Junior Member
Junior Member
I have a 270 inline six in my 57 GMC tow truck. It does not have an oil filter... It'll be easy enough to install a remote filter, however I'm not sure of the direction in which oil flows. There are two plugs on the block, #1 is towards the front of the block under the exhaust manifold and #2 in a located towards the rear of the block, a little high than #1. If I had to guess I would say that oil flows from #2 through the filter to #1... Thanks in advance for any help in this matter.
Allen A.
#143282 07/04/2005 8:04 AM
I'd try running the engine and loosening each plug a little and see which one leaks fastest;that'd be the pressure side.
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#143283 07/07/2005 6:57 AM
If i remember right, the inliners international website has details on how to convert the GMC engine to the full flow oil filter.
#143284 07/08/2005 2:19 AM
Junior Member
Junior Member
Thanks for the info on the web site... I'll see if I can find it...
Allen
