2 members (jaycoop, Otto Skorzeny), 108 guests, and 1 robot.
Topics128,131
Posts1,056,367
Members48,441
These triple pinstripe wheels came on my '36 when I bought it and before I post them for sale I wanted to know what they came off of. I have 4 center caps and unfortunately only 3 trim rings, they are mounted on 16x6 tires so I am assuming the rims are 16x5? Someone had told me '47chevy truck. Thoughts?
1936 Chevy 1/2 ton pickup
Curmudgeon
Curmudgeon
Info can be found at:
* Master Parts List
* Truck Shop Manual
http://chevy.oldcarmanualproject.com
* Vehicle Information
https://www.gmheritagecenter.com
They're probably 4" or 4.5" wide (measured between the bead mounting surfaces. If 4", they're 47-48? AD wheels, and if 4.5", 50?-55 1st AD wheels. The hubcaps are 41-47 1st style from the markings. AD hubcaps have block lettering - not as fancy. The pinstripes are typical for AD wheels.
thank you both for the great information
Clyde Willie I think those beauty rings were generic of the time,not chevy ?? The reason I say that my neighbors gave me a set that his Dad had on aChrysler . Fit my wheels fine,so swap meet.
