1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I recently put on a replacement updraft manifold on my 261. I had it milled and it seems to fit real well with no more hesitation on throttle. When I took it on the road however, it seems extra loud now. I figured the opposite would happen with the leak gone. The muffler isn't that old, so I'm wondering if anyone knows something obvious that I might be missing. Thanks in advance.
1958 Chevy Grumman Olson step van
| | | | | Joined: Feb 2019 Posts: 4,476 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,476 | I would recheck your work. It sounds like you have an exhaust leak somewhere. Did you use the alignment sleeves?
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Yes, used sleeves. Everything looks tight.
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I did have the heat riser removed and holes sealed. Would less restriction make it louder?
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I did have the heat riser removed and holes sealed. Would less restriction make it louder? Usually. By louder exhaust do you mean out the back or exhaust leak loud?
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | My recent drive this morning I think I do hear a vacuum leak.
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | **@#$!!&$@! I apologize, I just had to get that off my chest.
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I wondered if I'm running too lean.
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | It's real hard to give advice with limited info about the problem. Mike B  | | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | Sometimes a new gasket will shrink after it gets hot. My experience on a downdraft:
Installed new gaskets Torqued to specs Ran engine till hot Exhaust leak...expletive! Let it cool down a little (too hot for fingers) Rechecked torque..."loosey goosey" Retorqued No leaks
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Will the thick Remflex gasket fit an updraft manifold? I think it should, since the head ports are the same regardless of the type of intake that's used. Was there a good reason for eliminating the heat riser? I've been known to duplicate the heat riser shaft and flap valve in stainless steel, and put threaded-in bronze bushings in the manifold on some engines. Jerry
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I had a Reflex gasket on my last manifold and it worked well, however the leak was at the heat riser. I had another manifold which had the heat riser removed, and I had it sperated and milled. It sounds very good at idle and when I give it throttle. I sprayed water around gaskets with no difference. It's when I hit the road around10 mph under load that it makes a chug chug chug noise.
| | | | | Joined: Feb 2019 Posts: 4,476 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,476 | Have you checked the gasket between the intake and exhaust manifolds?
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I did install a new one after I thought that was the problem intitialy. A graphite type gasket to help with the suspected leak in that area.
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | After working on my van today I'm leaning towards exhaust leak. Downgraded engine performance, vibrations, and louder drivetrain emission.
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Phak1, I was thinking of exhaust gasket sorry. After I had the mating surfaces milled, one gasket was not enough to level the pipes. I had to use a metal cutout sandwiched between two gaskets.
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Anyone have a NOS updraft manifold? 🤣
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Chaz 58 Watch it now...your getting into propane territory like I do,take out heat riser weld holes shut with stainless. I suspect that updraft system would work good on propane don't need that sorry choke to wash your cylinders with gasoline every morning. They tell you not to mount propane carbs upside down,never saw a reason you couldn't if it leaks will run over either way. They hated that stub-nose fuel system in under there. | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I rechecked the manifold gaskets and one was off a little. A slight realignment and I sealed the leak. Feel blessed. Thanks for the assistance.
