1 members (Jon G), 151 guests, and 2 robots.
Topics128,167
Posts1,057,017
Members48,458
Page 3 of 10 1 2 3 4 5 … 9 10
Saved myself a few bucks for Christmas smile
Anyone know what size holes these should have? Just the bolt size? Or should the rubber sleeve poke through too?
1948 Chevy Thriftmaster 3/4-Ton
Poncho "farming" in Ontario
Starting in the DITY
Continuing in the Project Journals
More images
There are only 10 types of people in this world, those who can read binary and those who can't.
Actually Kevinski's pic says bolt hole size. Thanks!
More images
Headlight buckets cleaned up and ready to go in with new hardware. Next up, rust converter on the frame and then paint.
More images
Days and days of degreasing...
More images
Still prepping for paint. In the meantime, is this supposed to be bent?
More images
If you are asking about the tie bar, no it should be straight
Not an uncommon sight, but yes it should be straight.
So, take it off and drop the truck on it and put it back on?
More images
Find a tree with a nice stout crotch and straighten it back out so you can look down it and see that it's straight.
Maybe ratchet strap ,nice work on the headlight buckets they look like the ones I have Aluminum.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
First coat of some POR15 on the frame, will do two coats and then go back and do inside and bottom two coats.
More images
While painting, seen a weepy bolt in the steering box.
Is this a 'just give it a twist' and move on? Is the plug on the top to top up fluid? What fluid? Thx!
More images
It looks like the side cover if it is it should be okay to turn it tite a bit if it is. The steering boxes are famous for leaking and most use cornhead grease instead of the gear lube.it would not hurt to take the plug on the top out and look inside to see if there is any fluid in there.
"The Journey"
Follow in the DITY
So I'm running out of time before I have to get the hoist back to the owner. I haven't found a decent clutch kit yet and will likely have to get the engine in place before I do. How hard is it to put a clutch in with the engine in place? Assuming I should get the flywheel machined and installed first?
More images
It really doesn't matter whether the engine is installed or not, as you have to install the flywheel and clutch AFTER the bell housing is bolted on. Inspect the flywheel to see if it needs to be machined.
I'm wondering if it's worth trying to find this elusive 10-3/4" clutch kit. Local place will do a clutch and plate rebuild for $500, but the smaller clutch kits are way less. Would it be easier for me to just find a 6v flywheel with 6-bolts? Not like I will be hauling cattle in it...
More images
Have you tried Napa I found this but you would have to check as it looks like you have the heavy duty clutch.It may be worth it to go down to one of the older brake and clutch shops with your assembly to show them and see what they think
"The Journey"
Follow in the DITY
Local place will rebuild it for $500. Not sure if this is the norm, but it wasn't in the original budget 😒
More images
If the local place will check the pressure plate for way less than that, and find it good, you could just replace the disk (NAPA also lists that).
But for less than $200 a complete kit from NAPA is the way to go.
Napa doesn't seem to ship over the border and NAPA Canada does not have this clutch.
Here's a pic of the flywheel, any issues?
More images
Napa uses the same part numbers for both Canada and USA here I he Canada sites price .I thought used the Canadian site on the first picture but oops.
"The Journey"
Follow in the DITY
Ok was reading some more and came across a old thread and they mentioned the same Napa part number and the fellow said it does not have the 9 bolt ,so the Napa part looks like it wont fit he mentioned in another thread that chev of the fourties’ have the parts but they are not in a kit but separate and pricy
"The Journey"
Follow in the DITY
Thanks, ya looks like I can get mine rebuilt for the chev of the 40 prices.
For the flywheel, is this considered a 'stepped' one? Any concerns of the shape it's in?
More images
When I did mine I was told to machine the flywheel ( I don’t think it cost much it was like machining brake drums or rotors it has a stamp on it indicating the minimum thickness I think ) I would clean it up by hand with some emery cloth and see how it looks you would be able to see better if it has hardened spots or other imperfections from the clutch spinning and heating it up if it cleans up good I personally would leave it but I am no pro .Let’s see what others think
"The Journey"
Follow in the DITY
I just had my flywheel for 9" clutch resurfaced. Cost me $95 US (Alaska prices). I probably could have cleaned it up with some emery cloth, but it was kind of rusty and pitted. I agree with Kevinski. Clean the flywheel and look for hardened spots, cracks or deep gouges. If you find those, get it resurfaced.
Pretty deep pit.
Looks like burn marks too. Guess it's of to the machine shop
More images
Ok, here's the game plan, open to any suggestions...
Frame is painted, firewall Penetroled:
Next get the 216 balancer painted and installed - just line and rubber mallet?
Install bell housing - antiseize on bolts?
Motor mounts installed on engine and bell.
Install engine. Flywheel at machine shop now and still looking for a clutch.
Am I missing anything?
More images
No, use a heavy hammer and a block of wood. The rubber mallet will just bounce off.
Not antiseize - threadlocker.
Blue threadlocker? Will this go on most bolts?
More images
I'm using Permatex High Strength Red Gel currently. I was using Loctite 680, but that's because is was needed for a specific application.
But the only time you really might need high strength is for critical applications (driveshaft u-bolts, etc.)
Blue is probably fine for the bell housing and most other fasteners.
Ok, I'll pick up a blue and red.
More images
That took a stupid amount of time... Square holes suck
More images
Floor done, two coats of rust converter and two coats of POR15.
More images
Just heard back from the rad shop. To recore my Harrison 3121499 - $600+! Wow, things are adding up...
More images
First piece installed on new engine, balancer from the 216, with a little permatex in the key hole.
Next I will put Blue threadlocker on the bell housing bolts and tighten to 45-55lbs...
More images
Blue on motor mount bolts too?
More images
Looks like things are coming together,I don’t think I used much thread locker but that was years ago. .I do remember for the red that it won’t come off without heat found that out by breaking some bolts that had it on.
"The Journey"
Follow in the DITY
I'm assuming I need this? New one just has a bolt in it...
More images
That's the block drain for coolant. You can either use the petcock shown in your pic or a pipe plug (do NOT use a bolt, as it won't seal well in the tapered threads in the block and may damage them.)
Today's the day! Unwrapped for the first time and going in. Any suggestions?
More images
Moderated by  Phak1
