| | | Forums66 Topics128,032 Posts1,055,438 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 305 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 305 | I have a cheap primer gun I bought from Eastwood 10 years ago. The gun has a 1.8 tip I have no problem spraying primer except for high build primer. The tech sheet says use a1.6 to a 2.0 tip. I always run a lot of lacure thinner through the gun when I’m done. I don’t know why but the high build primer will sometimes clogg the small holes in the gun. I always stir it thoroughly and strain it before I put it in the gun . What am I doing wrong .Also is there a better way to clean the gun tip | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | You might need to reduce your primer a bit.
Also, if you don't break down your gun to clean it after every spray job, it is slowly clogging up. Just spraying cleaner through it won't cut it.
The reducer you use for the paint will clean the gun but it is very expensive to do it that way. I use SEM XXX Universal Gun Cleaner #77763. | | | | | Joined: May 2015 Posts: 11,004 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,004 | I've always found that gun cleaning was a PITA. I still have a 50+ year old suction feed gun that I painted my Model A and a couple other cars with, but don't use it at all anymore. My solution was a 3M Accuspray gun with their PPS system (disposable tips and cups) Current model. It cost me about $200, plus some additional for liners, etc. It cleans like a dream, and I'm still on my original 1.4 tip that I've used for primer on my current project so far. It takes about 3 ounces of solvent to clean the tip. The production shops use a gun cleaning machine, but those are pretty much out of reach of the hobby painter. Paint gun cleanerWhile looking that up, I also ran across this Gun cleaner spray that might be worth a try.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | I clean my guns between applications (flash times).. If it's drying on sheet metal its drying in the paint gun. | | | | | Joined: Dec 2014 Posts: 305 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 305 | I clean my guns between applications (flash times).. If it's drying on sheet metal its drying in the paint gun. That’s a good point The tip of my gun has been sitting in lacquer thinner about a week and I can’t seem to get the small holes open is it junk? | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | I have a paint gun cleaning kit that has various brushes in it and also various sized short wire sections, made for pushing through and clearing said holes.. Mine is a Snap-on, and likely not worth what they charge, but TCP global has this one, more economical... https://www.amazon.com/TCP-Global-P...a1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ== | | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | I have a Binks model 7 and a Binks model 37 that I bought new in '75, tear 'em down and clean with lacquer thinner each time. I just used the 37 to prime and paint my freshly sandblasted 22.5 wheels, gun still shoots like new.
| | | | | Joined: Mar 2014 Posts: 4,479 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,479 | If you were using catalyzed primer (epoxy primer) and allowed it to dry (cure) in your gun, I'm sorry to tell you that was a mistake you might not be able to correct. With some of these epoxy primers and paints, acetone will help dissolve them after they've been cured (hardened), but it isn't a promise. And your spray gun may never be the same again. We used to use MEK (methyl ethyl ketone), but if you can even find any MEK...use that stuff ONLY in well-ventilated areas, don't get it on you or your clothes and don't inhale it any more than you must. Lacquer thinner won't do much even over a very long time. Good luck.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | We use a 2.5 tip for 2k primer and a 3.0 for polyester (Feather Fill). Runs are WAY better than dry spray which has poor adhesion. Used to use our gun cleaning machine but the air motor went out and solvent is pricey so now we just trash can the Harbor Freight primer guns and lay out another thirty bucks for a replacement. Our finish guns are expensive; Iwata and Sata.
Evan
| | | | | Joined: Mar 2007 Posts: 3,374 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,374 | The Guard unit had one of those gun cleaning tanks in our shop. It was problematic and as Evan said the solvent was pricey. We used the old school siphon gun for our primer as we had quite a few and they were easier to clean. We sprayed finish coats with a Snap-On HVLP gun.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | |
