3 members (mick53, 1955 1 Series, Maybellene), 77 guests, and 1 robot.
Topics128,157
Posts1,056,872
Members48,456
Hello Bolters,
I made a rack for my 1951 chevy 3100. Someone asked if i wanted to send him the measurements i used. So I tought: "why don't share it with the rest of the community?" So here they are. Note that i'm from the Netherlands so i use Centimeters. But I wrote the inches on it. I suggest to measure or convert it for yourself so they are correct. I also put the length between the poles in it. Check if they are the same as yours before you make the rack yourself!
With kind regards,
Thijs
1951 Chevy 1300
"Selling trees in the Netherlands"
Follow along in the DITY Gallery
Here are the other pictures. If you have any questions don't hesitate to ask!!
Thijs
1951 Chevy 1300
Thijs,
Thanks for posting this.
What is the measurement of the space between the side and end rails?
Harold
Harold
If you measure from the pole on the side of the cab it is 26.6 inch (67.5 cm) till the first one and 51.8 inch (131.5 cm) till the second one. I also used 1.8 inch (4.5 cm) clearenance between the planks. I added another drawing to make it easier too see.
Hope this helps!
Thijs
1951 Chevy 1300
Quote
I also used 1.8 inch (4.5 cm) clearance between the planks.
Thanks, that is what I was looking for.
Harold
Harold
Very nice, thank you!
Brian
'51 Chevy 3604 Project
'28 Chevy LO basket case
'83 GMC Sierra 4x4
