8 members (NJC, cmayna, Hotrod Lincoln, lumbersawyer, JW51, 3B, cshades, 1 invisible), 100 guests, and 6 robots.
Topics128,064
Posts1,055,860
Members48,428
I looking to buy a 1954 Chevrolet 235 engine the casting number is 3835911 says it is a first series what is ment by first series does it have bearing inserts and is it a full pressure system????? Thanks!!! 1-262-392-2989 or [email protected]
Marv.
3835911 is a 1954 USA Chevrolet truck engine block casting code.
What is the Engine Serial Number pressed/stamped into the block on the "ledge" to the rear of the distributor?
Find and post other codes at the locations shown on this page. They will confirm date/year of the block and head.
Here is the number the guy sent to me 073I4I4f54Z Thanks for your help!!!!!!
Marv.
Would it have bearing inserts or not?????
Marv.
Marv.
Does the Shop Manual answer your question?
If I am not mistaken I read some were the 1954 235 with powerglide transmission had the inserts only on them or am I wrong. The engine I am looking has a four speed transmission on it also with the shifter on the top of the transmission most likely from a truck. What letter or number of the serial number does it show it is a manual transmission?????????
Marv.
Insert rod bearings starter with the 1953 Powerglige engine.
All 1954 and later engines used them.
My Blog
I found this on the Web Block 3835911 073I4I4F54Z
235 c.i.
truck
Block: 3701481, 3702436, 3835911
Head: 3835913
Engine Ser # T54 OR F54 FOLLOWED BY: L, LA, M, MA, MB, N, P, Q, R, S, T, TA, U, UA, UB, X, XZ, XB, Y, YE, YG, Z, ZC, ZE, ZH Pass??
http://1954advance-design.com/Stovebolt-engine/casting-numbers.html
1954 engine codes
My Blog
Dave,
Thanks for clearing thngs up!!!!!
Marv.
thumbs_up
My Blog
