| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 57 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 57 | My 61 C20's a daily driver. Still have torsion bars but swapped in disc brakes and 3.73 rear end last year so I'm on 6 lug wheels not 8. Tooling over to the big box, I started hearing random bangs from underneath at about 35-40 Mph. Like a hammer dangling on a string and just hitting stuff. Nothing's visibly loose but the ride height was visibly lower since the last time I took a good look. Put a turn and a half on the torsion bar adjusters and greased all the joints I could get the gun on in the driveway. ball joint boots torn on drivers side upper and passenger lower. Fairly new ball joints but I did a lot of hauling dirt and crush'n run last year. Is it possible the torsion bars decided 60 was their last birthday? I used to have a platoon of M60 tanks and a torsion bar cracking at night was a memorable wake up call. Don't see anything listed if I have to source a pair. I'll focus on the ball joints for now--I know they sound off pretty well if they start to go. Thoughts?
Ray Va Beach 61 C20 | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | How did you make the 6 lug wheels fit an 8 lug hub? If you're using some sort of a wheel adapter you might have one failing under the load. Jerry
| | | | | Joined: Nov 2008 Posts: 57 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 57 | After waiting 8 years for somebody to make a 8 lug disc conversion for 60-62, I bit the bullet and bought a 6 lug conversion including spindles and all. Rear end change also went from 8-6 lug. | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | So you turned a C-20 into a C-10, right? Unless you can find some "new old stock" torsion bars somewhere, it's doubtful you're going to find replacements. Jerry
