1 members (texczech), 51 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
#1432207 12/03/2021 7:42 PM
My 61 C20's a daily driver. Still have torsion bars but swapped in disc brakes and 3.73 rear end last year so I'm on 6 lug wheels not 8. Tooling over to the big box, I started hearing random bangs from underneath at about 35-40 Mph. Like a hammer dangling on a string and just hitting stuff. Nothing's visibly loose but the ride height was visibly lower since the last time I took a good look. Put a turn and a half on the torsion bar adjusters and greased all the joints I could get the gun on in the driveway. ball joint boots torn on drivers side upper and passenger lower. Fairly new ball joints but I did a lot of hauling dirt and crush'n run last year. Is it possible the torsion bars decided 60 was their last birthday? I used to have a platoon of M60 tanks and a torsion bar cracking at night was a memorable wake up call. Don't see anything listed if I have to source a pair. I'll focus on the ball joints for now--I know they sound off pretty well if they start to go. Thoughts?
Ray Va Beach
61 C20
Nomad02 #1432208 12/03/2021 7:59 PM
H Online: Content
How did you make the 6 lug wheels fit an 8 lug hub? If you're using some sort of a wheel adapter you might have one failing under the load.
After waiting 8 years for somebody to make a 8 lug disc conversion for 60-62, I bit the bullet and bought a 6 lug conversion including spindles and all. Rear end change also went from 8-6 lug.
Nomad02 #1432230 12/03/2021 9:48 PM
H Online: Content
So you turned a C-20 into a C-10, right? Unless you can find some "new old stock" torsion bars somewhere, it's doubtful you're going to find replacements.
