1 members (Alex52),
136
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2021 Posts: 3 Moderated | | Moderated Joined: Nov 2021 Posts: 3 | Hello all, I am new to thread and also the new owner of a 1946 Chevrolet 6100. Its been sitting indoors for about 35 years and needs a new radiator. My radiator shop said they were unable to repair. Anyone know a guy. I appreciate any feed back. | | | | | Joined: Sep 2010 Posts: 2,334 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,334 | You should be able to find a new one check online , surprised the shop did not want to price one out for you .Don’t go back to that shop . | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | Welcome Tucker. My local rad shop guy said he liked working on the old rads. I'm with Kevin, there must be another rad shop nearby. | | | | | Joined: Nov 2021 Posts: 3 Moderated | | Moderated Joined: Nov 2021 Posts: 3 | I should clarify. The shop did offer an option. Quite pricey. Was looking to see if there were any other leads out there. I will try a couple other shops. Thanks | | | | | Joined: Oct 2012 Posts: 130 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 130 | Tucker PM me. I may be able to help you out. Doug | | | | | Joined: Nov 2021 Posts: 3 Moderated | | Moderated Joined: Nov 2021 Posts: 3 | I do not have PM access at this time. Thanks for the offer though. My rad guy ended up doing better. | | | | | Joined: Apr 2020 Posts: 322 Professional procrastinator | | Professional procrastinator Joined: Apr 2020 Posts: 322 | Tucker, if Dougs does not work out I can help too. Rich
1947.2 GMC 1/2T SWB panel 1947.2 GMC 1/2T long bed 1948 GMC 1/2T short bed
| | | | | Joined: Feb 2010 Posts: 478 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 478 | Just keep in mind your radiator has 0 operation pressure if it's like mine on my 46 2 ton. (The over flow is far below the cap) I flushed mine out and shook it upside down to get the chunks of rusty metal out of it over 15 years ago and I've put about 3000 miles on it since and haven't had a problem. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Tucker Todd Would stay away from re-cores,usually ends in hard to fix seam leaks around tanks. Anyway mine did,about a year in. | | |
