0 members (),
297
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | With the cover off, I got the 4 7/16" distances between the outer edges of the forks and the outsides of the shifter grooves. Should be in neutral on both parts. I put on the cover and put in some bolts. I could shift from 2nd-->3rd-->4th but it just clanks when I try for 1st or reverse.
Does it have some thing to do with that gear down there that has straight cut gears (and not angled gears)? I could send some pictures later.
1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: May 2015 Posts: 11,152 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,152 | There's a lever that moves the 1st/reverse gear that pivots down one side of the tranny. The top end of that lever also has to line up on the top cover when installing it. You need to be sure that the two forks AND the lever are lined up when installing the cover. Somebody posted a link here to a video of the SM420 a while back. I'll see if I can find that. [on edit] the link is in this post. The lever and cover info appears at about 16 minutes in.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | Thanks Kevin. I think I was knocking the lever forward when I lower the cover. I positioned the lever a little bit to the rear and got it done. Thanks again! 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
