7 members (52Carl, Peggy M, Gdads51, papas52, Otto Skorzeny, baldeagle, 1 invisible), 138 guests, and 2 robots.
Topics128,165
Posts1,056,999
Members48,458
I have a 1968 C60 dump truck that I have recently installed all new brake lines and wheel cylinders. The brakes work great but now I am thinking about upgrading the single reservoir master cylinder to a dual for safety reasons. Can anyone tell me what master cylinder I should use or any dos and don'ts of this. Thank you in advance.
3B Offline
Hy miller873, welcome, is your truck a single axle or a tandem? Does your truck currently have power steering? Does your truck have an air compressor on it? Does your truck have a hydraulically actuated clutch?
Thank you for the quick response. It is a single axle. It has power steering. No air compressor. No hydraulic clutch. It does have a power brake booster. Thanks again.
3B Offline
Hy miller873, unfortunately the sixties are a time of change in the medium/ heavy truck hydraulic brake world. I found a part number for a dual system master cylinder which is listed for a 1968 C60, the part number is Raybestos MC36346. If you were to install this master cylinder you would either have to install another vacuum booster for the second brake system, or you could install a Hydroboost system on the firewall in front of the dual master cylinder. I am not sure if a combination valve would be required on a drum/drum brake system. If you have a medium/heavy truck wrecker near you he or she may be able to supply the parts for the conversion. The master cylinder is available from RockAuto for $205.89, hope that helps.
Thank you, I appreciate the input. I will check it out. From what I have read a proportioning valve isn't neccessary on drum/drum systems but I am sure not an expert on this. I would just like to assure that I still have some brakes if I lose fluid for some reason. Thanks again.
