5 members (DadsFirstPickup, homer52, Otto Skorzeny, dt235sd, 2-Ton), 71 guests, and 3 robots.
Topics128,049
Posts1,055,661
#1431510 11/27/2021 12:11 PM
Hi,
would anyone know who may 2 sets of door locators? mine are missing
one part on each frame and one on each door, thanks in advance
https://www.dropbox.com/s/0a200xy9f...314864_7735641265794593489_n_LI.jpg?dl=0
1959 Apache
""Rebuit everything and added a 440 Big Block"
Follow in the DITY
sssammm #1431511 11/27/2021 12:42 PM
Ex Hall Monitor
Ex Hall Monitor
Year? Model?
sssammm #1431513 11/27/2021 12:55 PM
1939 COE, AF I think
1959 Apache
Follow in the DITY
sssammm #1431533 11/27/2021 3:37 PM
Ex Hall Monitor
Ex Hall Monitor
If the picture is of your truck you have the retainer and only need the bumpers and maybe the dovetail if they're missing. Most of the vendors have them. Here's one supplier.
https://www.chevsofthe40s.com/detail/42122/Bumper_Door_Dovetail_Rubber_Bumper.html
https://www.chevsofthe40s.com/detail/39273/Chevrolet_Door_Dovetail_Wedge_Plate.html
sssammm #1431555 11/27/2021 6:59 PM
Its not my truck, as i said i need both parts, the ones you show look totally different, im getting
some better pics sent over, will post later
thx
1959 Apache
Follow in the DITY
sssammm #1431574 11/27/2021 10:11 PM
Ex Hall Monitor
Ex Hall Monitor
This is of my 38 car. The truck should be very similar. There is a spring under each of the bumpers. The repop bumpers used to come with the spring. I guess not so any more. The dovetail I listed above attaches to the door and slides between the bumpers in the picture. It's not a good photo but you can see the dovetail in the other picture on the edge of the door.
sssammm #1431579 11/27/2021 10:33 PM
Hi, heres a pic of what I need, similar to yours but not the same, dovetail is just a 2 screw fitting
need the bumper cover and innards and this dovetail
https://www.dropbox.com/s/cndcj1wl3p0lqf4/261076884_4589214654498069_4897574917145923619_n.jpg?dl=0
1959 Apache
Follow in the DITY
sssammm #1431633 11/28/2021 12:39 PM
Ex Hall Monitor
Ex Hall Monitor
How about a photo of the door jamb showing what you're missing. It looks like you have the dovetails on the doors. What you need will likely be very similar to the picture I posted above with the bumpers and cover but we don't know without seeing what you do have.
sssammm #1431672 11/28/2021 8:31 PM
As i said, i need everything, for the door and the shut, the pics are off someone elses truck same as mine
https://www.dropbox.com/s/w9juwxs60nbdb4d/261200320_1734329200095309_8773889625774081403_n%20%281%29.jpg?dl=0
1959 Apache
Follow in the DITY
sssammm #1431675 11/28/2021 9:02 PM
Ex Hall Monitor
Ex Hall Monitor
The best advise I can give you is to monitor ebay, put an ad here in the Truck Parts Wanted forum and register over on the VCCA.org chat site so you can put an ad in it's Parts Wanted Forum. If you see a seller on ebay who's parting out a truck you might contact them to see if they have the parts you want even if they're not listed for sale. FWIW the picture you just posted looks to be identical to the car setup. If you can find a pair for a car you can probably make them work. Good luck.
sssammm #1431736 11/29/2021 6:25 PM
Thanks Tiny
1959 Apache
Follow in the DITY
