1 members (Samantha),
45
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2020 Posts: 43 'Bolter | | 'Bolter Joined: Oct 2020 Posts: 43 | Happy Thanksgiving to everyone here! Not too long ago, there was a thread about pros and cons of using stainless steel nuts, bolts, and screws, to put sheet metal parts together, Can any one point me to that thread? Can anyone give me their thoughts now on pros/ cons of using stainless versus other types? There was discussion of "Spalling" which I have no experience of seeing. Thank you all for all the help. I learn new things here every day! Mike Stone. | | | | | Joined: May 2015 Posts: 11,163 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,163 | Stainless steel fasteners are fine. You just need to use anti-seize on the threads to prevent galling (not spalling) and being unable to tighten or loosen them. I experienced that when mounting a sonar transmitter on a boat. It locked up just prior to getting tight enough. I wound up snapping it off and getting a new screw and nut. I used anti-seize the second time.
Galvanized steel or zinc plated fasteners don't have that issue, because zinc is a softer metal and acts as a lubricant of sorts.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2016 Posts: 1,052 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,052 | I had the same issue when putting a new toilet in my sailboat. It was a nightmare. now I always use anti-seize. It's not a bad idea to use it on most bolts such as exhaust manifolds and even spark plugs. you can get a jar of it for a few bucks that will last a lifetime.
| | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Be aware that some anti seize compounds are not compatible with stainless steel. Check the label, or do a little research before deciding which product to use.
"Silver threads among the galled!" Jerry
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The only "pros" are they don't rust.
For interior sheet metal trim screws, stainless looks nice and shinny. Good choice.
The cons are galling (dissimilar metal problems), price, unnecessary.
Use Gr 5 hardware. The strength of Gr 5 is equal or greater than the SS hardware that vendors sell. Gr 5 used in our trucks won't rust for 50+ years.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Aug 2001 Posts: 3,616 Moderator | | Moderator Joined: Aug 2001 Posts: 3,616 | I have not heard that about any anti seize that is not compatible with stainless metal. Though some procedures did say to only use N-5000 on Safety related stainless bolting.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Low quality/off brand copper based anti seize can dry out and wash out and leave components/hardware unprotected. This warning is usually concerning aluminum, carbon steel, galvanized and sometimes stainless. Dissimilar metal situations. I think the top brand makers have overcome this issue.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | When we were installing stainless pipe with NPT threads for a new wine filtering system at E&J Gallo in Livingston CA, we were required to use an extremely expensive thread lube/anti seize compound to prevent galling of the threads. The maintenance foreman would get upset if he found a can of Never-Seez or regular pipe dope anywhere near that project. If a joint galled, there was no unscrewing it at all- - - - -get out the sawzall! Jerry
| | | | | Joined: Aug 2019 Posts: 251 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 251 | Ok Hotrod, you’re talking FOOD grade for the winery. I know we love our trucks, but I doubt Mike is planning to eat off his truck unless he’s building a classic Taco vending truck. Maybe we should be on the lookout at a future event.
1957 Chevy 3200Daily DriverPS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights. Follow in the DITY | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Hmmmm- - - - -and this is the same company that used lead/tin solder to assemble a steam-powered distillery capable of producing 2K gallons per hour of 99.5% pure ethanol! Jerry
