0 members (),
90
Mod | | | Forums66 Topics128,031 Posts1,055,434 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2021 Posts: 34 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 34 | I have a 1946 1/2 ton that I want to replace the clutch. Current clutch is an 11". Everything I have read said it calls for a 9 1/2 " . Any thoughts?
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Sep 2021 Posts: 34 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 34 | | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Not to old yet Put an 11 inch clutch in one of mine,it's just to stiff never seems like you go over center somehow. Just work to use it !! | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | If you want to go to the smaller clutch disc you'll also need to swap to a 6 bolt flywheel and pressure plate. Jerry
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Not to old yet You know my 51 6400 came to me with an original clutch that you would think was the biggest they used. It works as easy as pie,is smooth and I know it has hauled several swamper loads of corn out of the soft field. So go figure !! | | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | The clutch in my '57 LCF was completely frozen mid throw, mouse urine had seized the throw-out bearing to the input snout. Specs say 10-3/4 inch, I wanted a non-diaphram as was the original, bought one at the FLAPS for a V8 Belair with the same specs - works perfectly.
