1 members (stoveboltgator), 218 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#1430932 11/22/2021 12:09 AM
I have a 1946 1/2 ton that I want to replace the clutch. Current clutch is an 11". Everything I have read said it calls for a 9 1/2 " . Any thoughts?
Not to old yet #1430936 11/22/2021 12:59 AM
Ex Hall Monitor
Ex Hall Monitor
It looks like a 10 3/4" was optional on the 3100.
http://chevy.oldcarmanualproject.com/chevyresto/4688.htm
Not to old yet #1430943 11/22/2021 2:15 AM
Thank you.
Not to old yet #1431262 11/25/2021 12:18 AM
Not to old yet Put an 11 inch clutch in one of mine,it's just to stiff never seems like you go over center somehow. Just work to use it !!
Not to old yet #1431275 11/25/2021 1:59 AM
H Online: Content
If you want to go to the smaller clutch disc you'll also need to swap to a 6 bolt flywheel and pressure plate.
Not to old yet #1431315 11/25/2021 2:35 PM
Not to old yet You know my 51 6400 came to me with an original clutch that you would think was the biggest they used. It works as easy as pie,is smooth and I know it has hauled several swamper loads of corn out of the soft field. So go figure !!
Not to old yet #1431318 11/25/2021 2:44 PM
7
7 Offline
The clutch in my '57 LCF was completely frozen mid throw, mouse urine had seized the throw-out bearing to the input snout. Specs say 10-3/4 inch, I wanted a non-diaphram as was the original, bought one at the FLAPS for a V8 Belair with the same specs - works perfectly.
