| | | Forums66 Topics128,148 Posts1,056,809 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2021 Posts: 1 Moderated | | Moderated Joined: Nov 2021 Posts: 1 | I have a 1952 6400 that has been parked for many years. One rear brake drum has a crack, as a result of an attempt to free the stuck brakes. It was not a good day. Water under the bridge, and all that. I have searched the internet for brake parts but all I can find are drums for smaller trucks. There is a site that scanned old manuals of all kinds and posted them, and the parts catalog section that covered the brake drum is blank. I hoped to get the part number so I could continue my search online. This is a 10 lug drum, and I believe the brakes are Wagner. The shoes are on the top and bottom as opposed to front and rear. It is also held onto the hub by three small machine screws, which I believe they started doing in 1951. Is there a source for brakes parts such as this? Or in keeping with the guidelines for this forum, would it be worth it to post a want ad in the Swap Meet section? The drum | | | | | Joined: Feb 2016 Posts: 1,994 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,994 | I would post it in the wanted parts, some folks here are removing the axle and replacing with more modern so you do have a chance of finding one.
| | | | | Joined: Mar 2004 Posts: 6,228 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,228 | Your chances of finding a source for NEW drums are slim to none...place a ad and see what's out there used. Mike B  | | | | | Joined: Sep 2019 Posts: 204 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 204 | If you can't locate a brake drum through sources on stove take a few drives thru the farmlands near you. You might luck out and find a old truck that you can get parts off. It worked for me. | | | | | Joined: Oct 2007 Posts: 31 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 31 | Did you ever find your drum? | | | | | Joined: Sep 2019 Posts: 204 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 204 | There's a junkyard near me that has two advanced design trucks. I'll check them and make sure their the same mount as yours. If they are I can buy one and ship it to you. | | |
