6 members (KEVINSKI, klhansen, Otto Skorzeny, TUTS 59, dt235sd, 1 invisible), 118 guests, and 3 robots.
Topics128,095
Posts1,056,480
Members48,444
Looking for a diagram or photo showing the proper linkage connections from the accelerator pedal to the carburator..along with hand throttle. Thank you if you can provide such.
Here's a photo of the linkage at the engine. The throttle pedal is on the right and the vertical rod goes up to the carb.
I try to take pictures of everything, so I know how it goes back together. Then the only issue is flipping thru the photos to find the right one.
AD Addict & Tinkerer
Here is a page from the Factory Assembly Manual.
Phil
Project Journals
Stovebolt Gallery Forum
Curmudgeon
Curmudgeon
And at the carburetor.
Thank all of you for posting photos and diagrams. I went back and was able to reassemble the throttle linkage. Working in the daylight definitely helped.
New problem after starting. Will make another posting.
