5 members (Otto Skorzeny, Biermann, Ridgeback, Oswald, GMCJammer51), 72 guests, and 1 robot.
Topics128,154
Posts1,056,837
Members48,456
1950 Chevy 3100 216 3 Speed.
Does the rib on the steel strip that holds the lower door seal in place go up or down?
Darren
Current Project - 1950 3100 5 Window with a rebuilt 216 and 3 speed trans
Good question. I think flange down. It holds the weatherstrip down to the door flange as well as on the vertical portion. If you have the seal, you should be able to tell which way it goes.
Goes down the v fits on the door seal pushing it tite to the door. That’s the way I put mine.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Darren, see these photos of the strip, its gives you a visual of what Kevinski is describing.
Ron - - Dusty53
1954 Chevy 3604
Thank you. A picture is worth a thousand words!
Darren
