3 members (Hotrod Lincoln, BC59, 1 invisible),
134
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,047 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Hi Guys,
Has anyone tried to mount Silverado or new chevy truck wheels on a AD 1/2 truck? I see that the bolt patter will work but the center cutout diameter is a little smaller than the raised ring on the rear drum. the wheels are wider and require a wider tire. I think they would look nice and be a great second set of wheels and tires. Anyone try this already?
thanks, skipper | | | | | Joined: Feb 2021 Posts: 155 'Bolter | | 'Bolter Joined: Feb 2021 Posts: 155 | I also would like to know. I want to be sure I have the proper size so the speedometer doesn't get out of wack.
54 Chevy 3100 Deluxe 3 speed on column. Keeping original as possible but changed to 12 volt system. JB Weld..."I put that stuff on everything"
| | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | I believe you will find that the deep offset of the newer wheels will interfere with steering parts up front and possibly contact the rear springs unless you install thick spacers between the wheels and the hubs. The spacers will cause tire/fender contact problems and dangerous steering geometry errors. Jerry
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | I tried to put a set on my 58, but the hub bores on the 58 were too large to fit the hole in the rim. | | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | do you recall how large they were, could the wheel centers be cut out bigger to fit? | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | I still have the wheels. I will try to remember to measure them this weekend.
I want to say it was close to 3/16" too small. There was definitely enough meat there that the rims could be bored out if you had a good sized lathe. | | | | | Joined: Feb 2019 Posts: 4,472 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,472 | There was definitely enough meat there that the rims could be bored out if you had a good sized lathe. If you don’t own a fairly large lathe, the cost would far outweigh the savings. It’s not as easy as one would think. The steel wheel is indexed (centered) by the hub, both the center bore and the lugs. You can’t center it by the rim because the rims are not that concentric to the center section. You would need a fixture similar to an axle hub (with no center section) chucked in the lathe to do it properly. once you got the first one done, the next three would be easy (unbolt, remove, bolt on next rim). You could also use a face plate but setup would be lengthy (and costly) if you bring it to a shop. And that brings up another issue. I know that the tapered stud nuts will center the wheel on the hub, but the hub also centers the wheel. The center bore on a steel rim is flanged. Does cutting off the center flange and only riding on the thickness of the steel create an issue? I can’t answer that, but if it was mine, I wouldn’t do it. Just my two cents!
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | |
