| | | Forums66 Topics128,083 Posts1,056,327 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | What was the last model year that Chevrolet used generators in the pickup trucks?
Mike Burns 1940 Chev 1/2 ton 1953 Chev 1/2 ton 1950 Studebaker Starlight Coupe 1947 Indian Chief 1943 Indian 741
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | From a G-o-o-g-l-e Search: "Before 1963, General Motors used generators instead of alternators. They were often called dynamos or D.C. (direct current) generators. Since the only way to recharge an automotive-style wet cell battery is by using direct current, alternating current must be converted to direct current."1964 was the first year for an alternator.More than you want-to/need-to know? | | | | | Joined: Feb 2004 Posts: 29,825 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,825 | 1961, I believe. The 1st. generation alternator, called a "Delcotron" which used n external regulator was on the cars in 62, and I doubt that they would have run two different charging systems in the same production year. Jerry
| | | | | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | Chevy Corvair trucks were slow in changing. They used generators through 1964. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Chevy Corvair trucks were slow in changing. They used generators through 1964. Ooops, those Corvair trucks are not considered to be trucks here on Stovebolt.com. I consider them to be trucks - GM/Chevrolet lists them in their Truck Data Books. | | | | | Joined: Mar 2005 Posts: 155 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 155 | GM first introduced alternators on the new 1963 corvette. All other GM vehicles were alternator charged in 1964. Dubbed the 10 DN, the externally regulated Delcotron was GM’s new charger of choice through 1968, when the internally regulated alternator was introduced. - Motor Trend | | |
