4 members (54farmtruck, klhansen, UtahYork, pdlightning), 363 guests, and 2 robots.
Topics128,168
Posts1,057,098
Members48,463
#143003 06/18/2005 10:22 PM
Hey guys,
I was looking at 56 GMC 1.5 ton with the 6 cyl motor in it. The guy said this truck had a 6 volt system. Does that sound correct? All my 55-57 1.5 and 2 tons are 12 volt.
Should be 12 volt.
V
V Offline
I think it should be 12 volt BUT GMC did things a little different than chevy sometimes i had a 55 second series 3/4 ton that was 6volt
It should be a 12v. The last 6v GMCs were the '55.2 I6 models.
Of course, if it has an I6, and was mistitled as a '56 (sometimes they were titled by year of sale, not model year), it could be 6v. Check the body number at the website in my signature.
1954 GMC De Luxe COE
I believe GMC held on to 6 volt one more year than Chevy did. Weren't they Positive ground too? Pull a bulb and check the numbers on them. Think a dash bulb of 55 is 6, or back of headlight should say voltage if you pop one out. Generator tag sometimes says? OR color of it means something.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
if it's a 56 and 1 1/2 ton its 12 volt. the medium duty trucks were all supposed to be 12v that year.
All 6v GMCs were positive ground. V8 '55.2 GMCs were 12v negative ground.
Well it's home and its a 6 volt alright. The fun begins.....
How many cells does the battery have. 3 cells = 6 volt, 6 cells = 12v.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
It didn't come with a battery but the light bulbs are 6v.
Junior Member
Junior Member
i have a '56 gmc 1.5 ton and its 12v
All signs are its a 6 volt and we're gonna keep it that way. Thanks for your help.
