3 members (Otto Skorzeny, 68ironhead, mick53), 95 guests, and 1 robot.
Topics128,115
Posts1,056,624
Members48,450
The interior of my 53 pickup is patched up and painted. I am ready to start installing all of the internal components. This is probably a dumb question, but, is there any particular good order to do this. I don't want to get it half done and then have to tear it back out because I got ahead of myself.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
Mr Burns,
Which part of the interior are you talking about? Seat, gas tank, dash instruments, etc.
We need more info to guide you.
Chris
AD Addict & Tinkerer
The seat would be the last to install. Doesn’t matter if you install the dash components or the gas tank first, but installing the dash components is easier with the seat out. You can cut a piece of plywood to lay across the seat riser and block up the front of the plywood to make a nice place to lie while working under the dash. You could even add a cushion! I would even install the ceiling with the seat out.
Phil
Project Journals
Stovebolt Gallery Forum
Phak1 Sounds like a good plan,hadn't thought about doing headliner that way,would cut down on cussing LOL
Lots of cussing with the headliner...and the windlace weatherstrip.
54 Chevy 3100 Deluxe 3 speed on column. Keeping original as possible but changed to 12 volt system.
JB Weld..."I put that stuff on everything"
Thanks to all of you
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
Joe Dude I make cardboard headliners for my beaters,that way when I tear it I can just go ahead and demolish it !! Have learned to put 24 ozs. of moth balls above headliner to hold off the mice. Lasts about a winter here we have a lot of rodents !!
Here is the best way to keep the mice out of your truck over the winter:
I would add about 2" of water in the bottom. That drowns the little buggers, and they have a hard time jumping out of the water. I did that with an old bucket when we were staying at an old cabin, but the bucket had been shot full of holes, and they used the bullet holes to climb back out. We heard lots of them fall into the bucket and climb out all night long.
2 Offline
A new from factory AD cab allows mice to enter because it’s “the cab that breathes”
Mice can fit through the parking brake hole in early cabs
But also through the A Pilar bottom drain vent hole on all cabs
Then they climb up and pop out high under dash
To stop these openings I use stainless steel wool in the bottom of the pillars under the lower door hinges and I made custom better fitting floor sponge seal supports out of metal that sit ontop the transmission
There are also two drain vent holes on the back corners of the cab but these seem perhaps just small enough maybe mice can’t get in there, but more stainless steel wool can’t hurt much
So far the mice can’t get into my 1950 now but they are rampant in everything else.
-s
In upstate NY we used a five-gallon bucket and old radiator fluid that had anti-freeze it it (and a "plank" for the mice/rats/squirrels walked into the bucket). No worry about freezing.
We put peanut butter on the "roller" - it attracted the varmints.
- watch this to the end.
Simple & Inexpensive
Barn/Shop cats work real well also!
Charlie
'51 3100 5-Window (Restomod in progress)
Agreed
Yep, here in eastern NC.
Upstate NY - the cats would freeze.
Moderated by  ndkid275, Phak1
