5 members (3800GUY, Shardean, Stovebolt48, Peggy M, Hotrod Lincoln), 79 guests, and 6 robots.
Topics128,021
Posts1,055,349
Members48,420
#1429886 11/12/2021 10:54 AM
2 Offline
Whats the best way to remove the lead from cowl door piller areas ?
29tons #1429892 11/12/2021 1:33 PM
Soft flame and wire brush
29tons #1429962 11/13/2021 1:08 AM
Propane torch and a wire brush was all I needed. It was fun watching it pour off. It looked like mercury.
29tons #1430017 11/13/2021 4:16 PM
Professional procrastinator
Why remove it? I will be coming up on that decision soon.
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
29tons #1430022 11/13/2021 5:02 PM
H Online: Content
We always used a torch and a blow gun on an air hose.
Typically, it is cracking, rust is forming underneath, etc.
29tons #1430045 11/13/2021 7:54 PM
If it's not cracked or rusty in the surrounding areas like Mark says is typical, just leave it in place.
29tons #1430049 11/13/2021 8:24 PM
Mine is good but I notice the paint likes to peel off of the lead any prep to stop it from peeling .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
29tons #1430060 11/13/2021 10:19 PM
Moderator, Electrical Bay
You can grind a V or U in the crack and repair with JB Weld. I did this over 30 years ago and never had that trouble again. Good luck.
~ Jon
29tons #1430061 11/13/2021 10:34 PM
Or if you're REALLY talented, you could use lead to repair the crack. grin
29tons #1430062 11/13/2021 10:53 PM
H Online: Content
Where lead is concerned, being lucky is far better than being good! The trick is to tin the metal around where the lead is going to be applied with acid core solder. Then the next trick is to neutralize the acid after the fill is made to keep it from causing the paint to lift. These days, finding body lead and/or acid core solder or anything else containing lead is about as likely as finding a chicken with lips!
There are a couple of Devcon products known s "Epoxy Aluminum" and "Epoxy Steel" that are much better quality and more durable than JB Weld, and MUCH easier to apply than lead. In a place where there might be a little flexing involved, it would probably be a better choice than regular body filler. 40-something years ago we used a product from Ditzler/PPG called "Aluma-Lead" which was an aluminum powder that was mixed with some sort of liquid binder.
29tons #1430063 11/13/2021 11:45 PM
Maybe a member knows how well these products work?
- Alvin Lab-Metal
- All-Metal™ 1 qt Specialty Body Filler by USC®
29tons #1430076 11/14/2021 2:31 AM
I've used All-Metal. Works well as body filler. It was recommended to me by a body shop owner.
29tons #1430834 11/21/2021 12:17 AM
Torch and stainless brush. Welded seam and finished with metal to metal.
29tons #1430886 11/21/2021 5:23 PM
Beautiful work there!
Been looking at doing some lead seaming, I have quite a bit on hand for casting bullets - is it usually just pure lead used in these seams, or some specific alloy?
I'd think pure is best just to avoid spalling/cracking?
1949 Chevrolet 3/4 Ton - Still Solid. Regular Driver
OT Vehicles:
1925 Hudson Brougham Super Six
1950 Chevrolet Styline (Parts)
1952 Canuck Pontiac Sedan Delivery (Well Underway)
1973 F250 4x4 Highboy
1977 F250 4x4 Lowboy
29tons #1431126 11/24/2021 12:44 AM
29 tons My lead body teacher had a flame about 8 or 9 inches out there real gentle,he would just use the tip of that feather,kept his paddles in a quart oil can with just a little motor oil. This would be covered with a shop rag to keep the primer dust out and maybe set for days or weeks. Always used dutch boy lead real soft,eastwood lead is a hard alloy harder to use.
Northcoast 3800 Dutch boy body lead was 70% lead and 30%tin I think it said right on it,you could just bend itby hand.
tclederman #1431131 11/24/2021 12:55 AM
tclederman Have used eastwood all metal filler is fine,scratch it up nice and bright and rough !!
NorthCoast 3800 Just looked at eastwood lead is 30%lead 70%tin so may be wrong about the dutch boy 70/30 lead. I do recall that the eastwood lead was hard.
29tons #1431203 11/24/2021 5:10 PM
Thanks! I never searched for it just assumed it was generic alloy or pure lead!
I'm surprised it's not 70% lead/30% tin, if not pure lead. Would have thought that would make it too brittle. Interesting!
OT Vehicles:
29tons #1431232 11/24/2021 8:17 PM
Interesting factoid: To identify if a stick of lead solder has tin in it, hold it up to your ear and bend it. If it makes noise (called "tin cry") it has tin in it. My dad taught that to me at his plumbing shop when I was a kid.
Tin in lead makes it flow better. A 70/30 lead/tin alloy is typical solder (but no longer legal for soldering water pipes).
klhansen #1431293 11/25/2021 5:06 AM
That IS an interesting factoid!
OT Vehicles:
29tons #1431316 11/25/2021 2:39 PM
H Online: Content
When I helped rebuild the distillery at E & J Gallo winery in 1979 they had us using lead/tin solder to install the copper evaporator cups. Every backwoods moonshiner knows better than to do that! That still was steam powered, 6 feet across, five stories tall, and capable of producing 2K gallons per hour of 99.5% pure alcohol (190 proof) from the dregs and leftovers of the winemaking process that still contained some alcohol. It was used to fortify the apple and pear juice based generic white wine used in products like Boone's Farm wine, and Bartles and James wine coolers. That stuff would only ferment to around 8% alcohol content due to a low sugar concentration. The raw alcohol brought it up to 12%, then it was colored and flavored artificially. At least it was marginally better than Mad Dog 20/20!
