Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Otto Skorzeny, Gdads51, Phak1, 1 invisible), 110 guests, and 4 robots.
Topics128,281
Posts1,058,472
Members48,490
#1428651 10/31/2021 6:55 PM
1953 3100 5win 325
1953 3100 5win 325
1953 3100 with stock brakes
Slow leak identified in the main cylinder. Need to refill the main cylinder with fluid. Any suggestions on what type of fluid I should use?
Thanks...
I am sure this will start a discussion -but I use Dot 3 in my 53 3100
1953 3100
Dot 3 is really the only choice. You could use Dot 4, my recollection is it has a higher boil point. Not really an issue for most of us. Dot 5, silicone fluid....you'd need to do a full rebuild, replacing all the rubber seals and o-rings. Then if no moisture ever entered the (should be) sealed system, it'd be good for years, if not decades. But really, Dot 3 is the one.
RonR
RonR
1970 340 Duster
1964 CJ5
Curmudgeon
Curmudgeon
DOT 3 agree.
In case you didn't know and sorry for the preaching:
If the leak is in an original master cylinder then there is no second cylinder typical of today's design.
All your eggs are in one basket. You want to fix the problem ASAP. It's not safe.
Make sure your parking brake is working.
Ditto on Dot 3 and more importantly on safety. Upgrade to a dual bowl mastercylinder
