4 members (Hush, Wheelie, WICruiser, Gray_Ghost), 104 guests, and 3 robots.
Topics128,084
Posts1,056,083
Members48,434
#142959 06/14/2005 2:16 AM
Here's what I've found - a red and black '50 Chevy with an 8' flatbed, dually rear, and the one-ton-style 8-lugs front and back. Exceptionally straight truck all around, solid Oklahoma truck, older repaint. Advertised as a 3/4-ton, though. Haven't seen under the hood, heard it run, nor seen the data plate yet. A bit much on the price, though, at $3K. Is this likely a one-ton? There are no emblems on the sides, only the hood emblem on the front.
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
#142960 06/14/2005 3:27 AM
Chances are, It is a 1 ton.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#142961 06/14/2005 5:15 AM
What is the wheelbase? Aren't all 1-tons 137 inches?
#142962 06/14/2005 10:43 AM
The responses to my post 1/2 vs 3/4...may help here as well.
