7 members (MickeyP, JW51, Gdads51, moparguy, Robert Crandall, Charles in CA, 1 invisible),
213
7
Mod | | | Forums66 Topics128,093 Posts1,056,152 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | Here's what I've found - a red and black '50 Chevy with an 8' flatbed, dually rear, and the one-ton-style 8-lugs front and back. Exceptionally straight truck all around, solid Oklahoma truck, older repaint. Advertised as a 3/4-ton, though. Haven't seen under the hood, heard it run, nor seen the data plate yet. A bit much on the price, though, at $3K. Is this likely a one-ton? There are no emblems on the sides, only the hood emblem on the front.
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Chances are, It is a 1 ton. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | What is the wheelbase? Aren't all 1-tons 137 inches?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2005 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 38 | The responses to my post 1/2 vs 3/4...may help here as well. Bill | | |
