2 members (Wooley, 59 fleet), 70 guests, and 4 robots.
Topics128,096
Posts1,056,488
Members48,444
Page 1 of 3 1 2 3
#1425230 09/26/2021 6:20 PM
Hello,
Looking to do some planning on my engine swap and want to start with the transmission. I have my original '48 SM420 in the truck behind the 216 and it needs new seals, but seems to be in great shape. I also have an SM420 out of a '56 truck or around there. I'm going to be doing a new gasket in whichever i go with, but should there be any difference between using one or the other? The original has the longer 'snout' on the back with that ball-joint thing. Does this mean my driveshaft would be too short if I went without it?
FYI, I will be dropping in a 261 and the rear has been changed to 4.10.
Thanks!
1948 Chevy Thriftmaster 3/4-Ton
Poncho "farming" in Ontario
Starting in the DITY
Continuing in the Project Journals
More images
There are only 10 types of people in this world, those who can read binary and those who can't.
The '48 two piece driveshaft is half enclosed on the front. The '56 driveshaft is open on both halves.
Not sure if it would be a bolt in, may require some length modification.
So, I don't think this is considered a torque tube, but I could be wrong:
[img]https://www.stovebolt.com/ubbthread...umber/35473/filename/20210225_180110.jpg[/img]
On the other hand, the spare (later) sm420 has this:
[img]https://www.stovebolt.com/ubbthread...umber/35474/filename/20210225_180023.jpg[/img]
More images
Photo #1 is indeed the torque tube. Photo #2 is for a conventional open drive shaft.
Ok, I guess that answers a question that should have been obvious wink So is there anything to gain by putting the later model trans in place with the torque tube?
More images
You won't be able to make the later model trans work with a torque tube. You need to match the driveline with the tranny and rear axle that you're using. If you still have the torque tube rear axle, you'll need to use the earlier tranny.
Ok, I was told that the trans case was the same and I would only need to swap the rear bits. If this is not the case, I suppose I'll leave it at that.
What are the chances that the speedo gears in the newer trans would be for 4.10 gears and would make my current speedo more accurate? Pretty sure it came out of a later 3100...
More images
The open shaft transmission is indeed out of a small truck with parking brakes in the rear axle drums. All of the big trucks have a parking brake attached at the rear of the transmission.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks Mike, so being that this is out of a 3100, would the speedo gear in the other trans be more accurate since I've gone from 4.53 to 4.10? Can I just replace one or do they have to change as a set?
More images
Goach2. The housing on the end of the trans can be swapped. The open trans will fit just fine, in place of the "closed" trans. You will need to take all the bits from the torque tube trans and put them on the open one if that is the way you choose to go. The speedometer drive is a matched pair. So that will have to be changed over as well. 4.10 is standard for the 1/2 ton. So that set should work just fine. The housing on the tail will match right up, so will the trunnion bearing support. Gaskets sets often come with both sets in one box. There are some differences inside the 48 vs the 56. Some loose bearings vs a caged set. But the gaskets are all the same. I even think the speedo drive will swap just fine. The 48 is a good one, so just re-gasket, swap the speedo drive and you should be fine. No major disassembly would be needed. Read the manual to set the "ball" seal shims and put it back in. Washing will be the worst part of the job.
Steve H
Thanks Steve - I will be dropping the trans soon, so should have some pics of the process.
More images
Ok, time for cleanup, then I guess compare this one with my spare to see which is in the best shape to use and install my gasket set:
[img]https://www.stovebolt.com/ubbthread...umber/36541/filename/20211104_203322.jpg[/img][img]https://www.stovebolt.com/ubbthread...umber/36542/filename/20211104_203331.jpg[/img]
More images
About 20lbs lighter now. Bottom half is pretty wet, so probably leaking from the front? Any concerns from the pics? Can I stuff a rag in the top and back u-joint and then power wash it?
[img]https://www.stovebolt.com/ubbthread...umber/36562/filename/20211105_191633.jpg[/img][img]https://www.stovebolt.com/ubbthread...umber/36563/filename/20211105_191642.jpg[/img]
More images
[img]https://www.stovebolt.com/ubbthread...umber/36576/filename/20211106_184236.jpg[/img]Degreased, what do I need to do to assess the condition of this?
Also, is this normal?
https://photos.app.goo.gl/PnXT1UmJykLXhjWm6
More images
I think it’s a little loose there are bearings under there that you can replace ,there are kits and some videos online showing rebuilding the sm420.check you newer trans the same way and see how much it moves for comparison .I would also take the top of the trans off to see what it looks like inside
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Put a kit into it. Pretty easy includes all new bearings and needle bearings too and gaskets for about $125 on flea bay. You will need a press and some bearing separators from harbor freight. I've done about a dozen of the sm420, pretty straightforward. Syncros are still available but if it is shifting well wouldnt bother.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Front bearing has way too much play:
https://photos.app.goo.gl/W11jC3VaJUXhwjHs8
Synchros have some wear, not sure how bad they look:
[img]https://www.stovebolt.com/ubbthread...umber/36579/filename/20211106_194312.jpg[/img][img]https://www.stovebolt.com/ubbthread...umber/36580/filename/20211106_194316.jpg[/img]
I have all the gaskets for this trans. Guess I should look at the spare now to see if it"s any better.
More images
[img]https://www.stovebolt.com/ubbthread...umber/36581/filename/20211106_195805.jpg[/img]
Spare (newer) trans has less wiggle, but clearly it was exposed to a bit of weather. Has different coloured synchros too. Not sure if there's any value in rebuilding one over the other...
More images
I have one like that ,looks like you will have enough parts to make one good one there are some parts that are not available for the sm 420 .look up Denny Graham up top on the member list he has a good pictorial of a rebuild as well as a stand for the transmission.
"The Journey"
Follow in the DITY
When I got this truck, it had no rear motor mounts. I would say that would likely cause ths input bearing wear. Since everything else looks good and I've been driving it for 5 years with no complaint, can I change out this bearing only and regasket and move on? I don't have access to a press and the secondary shaft with the freeze plug type end worries me.
More images
I have only taken one apart so far ,there are a few videos on YouTube.If it worked okay before then that may be all that needs to be done .did you open up the top of the original transmission to see how it is .My truck has the origional still in it and I plan on putting a newer trans from a 67 truck as it looks good inside and has the switch for the back up lights in case I want to add the lights later.
"The Journey"
Follow in the DITY
I have no complaints about how it drove, but 2nd to 3rd was always the most difficult and it looks like this is about where it would pivot, so perhaps changing this bearing would be enough
More images
[img]https://www.stovebolt.com/ubbthread...umber/36629/filename/20211106_194312.jpg[/img]
This first set of synchros has some wear to them. The ones in the other trans look really good, however it's not brass. I've read that the brass ones are actually better than the later ones. So is it worth replacing some that have wear with some that aren't brass but in good shape?
More images
Having difficulty tracking down the part number for the input shaft bearings. Does anyone have this to share?
More images
Rockauto has a NATIONAL 207L for the input shaft bearing, but it ways for the 3-speed. Does the 3 and 4 use the same bearing?
More images
Try QU51093. Found that here.
Got a part number off the box in the youtube rebuild video. 6209NR 45x85x19 ball bearing with snap ring. I can get this locally, so hopefully it's the right one. Are input and output bearings the same?
[img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/36678/filename/Trans bearing.jpg[/img]
More images
The one I found said 40mm ID, so different than your 6209NR at 45mm. ohwell
I know, wish someone could confirm, but I did get a better screen grab:
[img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/36682/filename/Trans bearing 2.jpg[/img]
More images
I'd go with the one from the video. I watched that and saw that number as well. I'm an expert on the SM420 now. grin
Which bearings I have a transmission sitting on the floor of the garage in parts.
"The Journey"
Follow in the DITY
There are two that I can see numbers and the other is still on the shaft .
"The Journey"
Follow in the DITY
The bearing on the shaft is the older ball bearing type depicted in the diagram as 4a,4b,4c.I don’t see any numbers on it .maybe if I take more apart.
"The Journey"
Follow in the DITY
4b and 41 is what I'm trying to get part numbers for.
More images
I will take a look to see if I can get it off the shaft tomorrow to see if it has a number on it
"The Journey"
Follow in the DITY
Tried to get at the bearing ,but no luck I don’t have the proper tool ,I tried a punch but doesn’t move also the diagram I posted above does not look like a sm 420 but is similar .so there may only be the ball type bearing.
"The Journey"
Follow in the DITY
Ah, good to know, thanks for the follow up.
Back to an earlier question, I have a nice set of synchros out of a newer trans, but they're not brass. Is it worth replacing if it's only for 4th gear, which performs just fine? Here's the wear:
[img]https://www.stovebolt.com/ubbthread...umber/36728/filename/20211110_103822.jpg[/img]
More images
Kevinski - Any chance you can confirm the input and output shaft bearings are the same size? thx!
More images
Not a whole lot of feedback on this, so here is my plan (up for critique):
1 - Replace the input bearing with 6209NR 45x85x19, still not sure what the rear shaft bearing is, so will leave it
2 - Leave the worn-looking 4th gear and synchro, as I have a set in perfect condition from a later model, but they're not brass and no one could confirm if it was worth swapping
3 - Change out all gaskets
4 - Replace the 10-3/4" clutch and pressure plate, if I can locate one.
Thoughts?
More images
I just ordered a 9" clutch kit from NAPA and saw that they had the 10-3/4" clutch listed as well.
Page 1 of 3 1 2 3
