2 members (Gdads51, TexasA&M48Truck), 185 guests, and 2 robots.
Topics128,047
Posts1,055,532
Members48,424
#1428741 11/01/2021 1:07 PM
I put an additional ground wire to block from battery and left the frame ground. Is there a problem when you use two ground wires ?
1964 Stepside C10
"Well we didn't get all dressed up for nothing." ~ Braveheart
Maybe overkill but won’t hurt anything.
Two more connections to get loose, corrode, and cause problems. Put the heavy ground cable to the engine block to carry starter current, and use smaller ground straps to the cab, frame, and bed for good lighting and other lower current circuits.
