| | | Forums66 Topics128,110 Posts1,056,255 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 38 | Ok guys, As I keep finding these AD trucks how do I tell a 3/4 ton vs 1 ton? Thanks, Bill | | | | | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | its easy to tell because very few 1 tons had beds but if theres no bed on it the one ton should have dully wheels on the back | | | | | Joined: May 2005 Posts: 33 Member | | Member Joined: May 2005 Posts: 33 | I believe all 1 tons had a 9' bed if it had a bed. I don't know if the wheelbase is longer, but my '48 1ton will fit a spare tire on the side without touching the fender. Other than that, the serial # should have FS in it for 1ton & a weight rating of 8800 lbs. It's hard to tell visually.
Life is good. Keep on playing.
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | 1-ton has 137 inch wheelbase. 3/4-ton is just 125. 1/2-ton is 116 (some 1/2-ton GMC's are 125).
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | bill mostly correct but if it,s got a bed -1 ton had 4 stake pockets per side-3/4 ton 3 pockets. 1/2 ton 2 pockets.  regards and welcome steve sr. | | | | | Joined: Apr 2005 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 38 | Thanks guys, I appriciate the guidance. | | | | | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | I think Wheel base will tell you the best. | | |
